2011-08-13, 10:44
Im looking to build a HTPC to run XBMC to play back my libary of movies and tvshows most of which is either 720p HD or 1080pHD. I have read eskros build forum and found it quite helpful in getting started on choosing my components etc. Im basically just looking for conformation if the parts i have choosen are compatible and can do everything i need. they are:
.cpu http://www.newegg.com/Product/Product.as...6819116399
.mobo http://www.newegg.com/Product/Product.as...6813130588
.psu http://www.newegg.com/Product/Product.as...6817139026
.ram http://www.overclockers.co.uk/showproduc...=MY-183-OC
.gpu http://www.overclockers.co.uk/showproduc...=GX-259-AS
.case http://www.scan.co.uk/products/silversto...atx-psu%29
i will also be adding a 2tb WD HD which i already have along with a wireless keyboard/mouse and wireless adapter.
Is there any part of the build you would change or is there anything i need to add like fans etc. thanks in advance for any replies
