Is it possible to somehow delete the files for a library entry from within XBMC?
I think you can do it if you browse files.
File Manager. You can get to it on the default skin by going to the System submenu.
Context Menu > Remove from Library.
Make sure file deletion and renaming is enabled in settings.
