2011-08-13, 19:28
I keep getting the above error while trying to add items to the menu like "Kids TV". This is what I have done so far.
- Install XBMC 10.1 live ISO from XBMC.org and installed to HDD
- Installed Passion repo from zip and installed the Aeon Nox SVN
So then tried to go to System->Settings->Skin and Favourites Shortcuts but when I tried to add a new button got "Cant find favourites.xml" so I created a file called favourites.xml and put it in .xbmx/userdata. After doing that I got "Error script failed script.favourites"
So I have also tried to install the favourites script 1.0.6 and 1.0.5 from zip but nothing happens so I have manually copied the contents of the favourites script zip in to /.xbmc/addons and restarted but still get the same error.
It may be that my favourites.xml file empty as I created this as it wasn't there and didn't know what was supposed to go in it.
Under system info it says XBMC 10.1 Git:Unknown (Compiled:Mar 9 2011) if this helps.
Also I have now reinstalled XBMC from scratch 3 times and also tried updating to the nightly XBMX 11.0 but still have the same problem.
