Hi
is it possible to turn off the movie info popup when using the Fanart wrap setting... nothing personal I just find it very anoying
Cheers Borg101
Hi Borg101
Well there's no configurable option in skin settings to do that so the only way would be to manually edit the includes.xml - do you want to do that? If you do let me know what version of the skin you're using (dharma or eden-pre) and I'll tell you what line to alter.
Cheers
Hi Sharpe
I give the editing thing a go ..Im using eden-pre version of the skin..
ps this skin just keeps getting better
Okay then edit Common Video Library Views.xml find line 14966 and remove this include:
<include>MovieInfo</include>
That should sort it for you.
Cheers
Thanks Sharpe for taking the time to work it out for me
It worked a Treat..
thanks again
Hello,
I have the same issue but i m using the dharma 10.1. Is it the same line? Plz help.
Thank You
I think it's line 17390 - but I've not looked at the Dharma version in months
