With the newest nighly (8th August) and the Stable release from 23rd July i have problems to play my recorded files (mpg or ts).
The audio is correct but the video is to much too slow.
I tested the sync options but can't get a solution.
In the forum i found a nighly Version from 07.06.2011 - this works fine:
http://dl.dropbox.com/u/867331/latest_at...ly2011.deb
What's wrong here?
tatoosh Wrote:What's wrong here?
Hmmmm let me see my magic 8 ball says your wireless network is too slow
chuckles Wrote:your wireless network is too slow
No this is defenetly no network problem. I use 1000mbit/s ethernet cable and with the "old" release the MPG files play well.
I have also tried it over 300mbit/s WLAN N Standard - same issue.
_-Sky-_ Wrote:For more efficient problem resolution, you must give more informations (log file, network type and speed, video sample, etc.).
See this post : http://forum.xbmc.org/showthread.php?tid=92480
Thanks for the link.
I will give you all informations:
1. Video Format
Testfile Link (10min):
http://dl.dropbox.com/u/867331/ATV/TStestfile.zip
General TS File
Complete name : T:\Made in America (08-14_11-11-40_RTL Television).ts
Format : MPEG-TS
File size : 220 MiB
Duration : 8mn 19s
Overall bit rate : 3 697 Kbps
Video
Menu ID : 12003 (0x2EE3)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Codec ID : 2
Duration : 8mn 18s
Bit rate mode : Variable
Bit rate : 3 320 Kbps
Maximum bit rate : 15.0 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.320
Stream size : 197 MiB (90%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 8mn 18s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -367ms
Stream size : 11.4 MiB (5%)
Language : German
Language, more info : Clean effects
General MPG File
Complete name : T:\AWZ\testfile.mpg
Format : MPEG-PS
File size : 2.30 GiB
Duration : 1h 25mn
Overall bit rate : 3 837 Kbps
Video
Format : MPEG Video
Duration : 1h 25mn
Bit rate : 3 569 Kbps
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.344
Stream size : 2.14 GiB (93%)
Audio
Format : MPEG Audio
Duration : 1h 25mn
Bit rate : 192 Kbps
Delay relative to video : -415ms
Stream size : 118 MiB (5%)
2. Platform
3. Installed / Updated XBMC Version
with NITO
XBMC Build version and date compiled:
this one is working: (10.4.0 AppleTV2,1). Built on Jun 7 2011 (Git:20110606-1d77fa0)
this newest nighly build and the stable build from 23th June is not working: (10.4.0 AppleTV2,1). Built on Aug 8 2011 (Git:20110808-6b994c5
4. Logs
All logfiles compressed in 1 file: http://dl.dropbox.com/u/867331/ATV/ATV2_allLogfiles.zip
5. Network
1000MBit Ethernet, 100MBit Ethernet, 300MBit WLAN tested ... all the same issue
My Problem:
With the XBMC builds newer than 7.6.2011 the FPS go down from 25fps to 11-13fps !!
So i downgrade the XBMC to run my MPG and TS file that i record with my PC:
ssh ...
downgrading org.xbmc.xbmc-atv2 from 10.0-9 to 10.0-7
Should i update my ATV Firmware ??
I've uploaded a testfile. Can someone please test this one ??
I don't know why the files do not work with the new builds ...
Hi tatoosh,
I have the exact same problem, so to which iOS version you upgraded? is it the current latest build 8F455 ?
some issue are reported on this build, as in this post:
http://forum.xbmc.org/showpost.php?p=867...stcount=46
did you experienced any problem installing XBMC or have any important issue not working after the iOS upgrade?
