Full Version: Shared MySQL Database Help
I'm trying to set up a shared MySQL database. I did this easily once before on Snow Leopard. This is an attempt on Lion.
The XBMC log file is full of these:
18:45:02 T:2893275840   ERROR: Unable to open database xbmc_video
18:45:02 T:2893275840   ERROR: Unable to open database: xbmc_video [1045](Access denied for user 'xbmc'@'bleach' (using password: YES))
Here is a transcript of my attempt to create the MySQL database:
mysql> CREATE USER 'xbmc' IDENTIFIED BY 'xbmc';
Query OK, 0 rows affected (0.00 sec)
mysql> CREATE DATABASE xbmc_video CHARACTER SET latin1 COLLATE latin1_general_ci;
Query OK, 1 row affected (0.03 sec)
mysql> CREATE DATABASE xbmc_music CHARACTER SET latin1 COLLATE latin1_general_ci;
Query OK, 1 row affected (0.04 sec)
mysql> GRANT ALL ON *.* TO 'xbmc';
mysql> select host,user from mysql.user;
| host      | user |
| %         | xbmc |
| 127.0.0.1 | root |
| ::1       | root |
| Bleach    |      |
| Bleach    | root |
| localhost |      |
| localhost | root |
7 rows in set (0.00 sec)
mysql> show databases;
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| test               |
| xbmc_music         |
| xbmc_video         |
6 rows in set (0.07 sec)
Here's my advanced settings.xml file:
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.0.75</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_video</name>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
<name>xbmc_music</name>
</musicdatabase>
</advancedsettings>
(The exact same file worked fine when the machine was running SL.)
What have I done wrong here? I can't help but think I'm missing something.
This is on XBMC a75cce4. I should add that I did not install Lion over SL. I installed Lion on an external drive and migrated everything, except for a few users, onto the external drive.
mysql> CREATE USER 'xbmc'@'bleach' IDENTIFIED BY 'xbmc';
should do it ... or you use 127.0.0.1 as mysql ip - one of both or both should work imho
Odd. The first time I tried that it failed. Rebooted, tried again and it worked.
Turns out you need two xbmc users; one with no named host the other as you wrote above.
mhh ... on the second look you already had an user "xbmc" for the host % which means all hosts ... so my suggestion should have been superfluious...
Somehow the host "%" doesn't work for localhost. I went back and dissected MySQL on Snow Leopard and see that I had to have two xbmc users: one with all hosts (%) and one with name of the localhost ("Bleach" in my case.)
