I don't find my XBMC folders on Lion
who can help?
VF
vmsferreira Wrote:I don't find my XBMC folders on Lion who can help?
VF
homefolder/Library/Application Support/XBMC
in my homefolder don't have any Library folder
vmsferreira Wrote:in my homefolder don't have any Library folder
Oh yeah forgot about that, by default in Lion now it is missing as Apple apparently don't want you messing around in there. Fire up Terminal (Applications -> Utilities) and then run this bit of code:
chflags nohidden ~/Library/
Check back it should be there.
Just a note if you update to 10.7.1 you will need to redo this as I have just found out.
Go to the "GO" menu in the finder menu bar and hold down option "Library" folder will appear.
Thewolf
You are the man.. I have been searching for weeks to find my xbmc folder under lion.. who knew all I had to do was hold down the option key to bring up library. When i said goto folder and type in //library/ it didn't come up with xbmc under application support.. now it does.. you are a true legend
