Full Version: How to use new confluence skin with XBMCLive
Hi all.
Is it possible to get the new confluence skin from the Pre-11.0 build of XBMC working with the existing XBMClive release (10.1, 2011.03.09)?
I've had no luck with it. While the skin loads, anytime you try to open one of the video menus, you get a blank screen. All other menus (system, music, weather, programs etc) work fine.
The xbmc log reports the following:
21:32:32 T:3053688704 M:573394944 ERROR: TranslateResolution invalid resolution specified for
21:32:33 T:3053688704 M:581246976 ERROR: Previous line repeats 5 times.
21:32:33 T:3053688704 M:581246976 ERROR: GetDirectory - Error getting /home/media/.xbmc/addons/skin.confluence/PAL
21:32:33 T:3053688704 M:580984832 ERROR: TranslateResolution invalid resolution specified for
21:32:41 T:3053688704 M:576200704 ERROR: Previous line repeats 5 times.
21:32:41 T:3053688704 M:576200704 ERROR: unable to load:/home/media/.xbmc/addons/skin.confluence/PAL/MyVideo.xml, Line 0
Failed to open file
Failing some catastrophic incompatibility, is it possible to be able to update an XBMClive installation to use nightlies? From what i've been able to find out, it doesn't seem like its possible?
