Full Version: Need an IR Receiver that works with Harmony One
Just discovered I have the wrong IR receiver to make use of my Harmony One's MCE Keyboard profile.
Can anyone recommend an IR Receiver that will work with the Harmony One remote? More specifically I need it to work with the MCE Keyboard profile. Thanks to JHSRENNIE I've learned that I need an RC6 or an eHome IR receiver, but I have no idea where to find one. While I'd prefer to purchase just the receiver, I'm willing to buy any remote product that comes with said receiver.
Prefereably something I can run to my local Best Buy, or Home Theater store, or Radio Shack, to purchase, but I'm willing to order online if I have to.
Any recommendations?
Thank you!
http://forum.xbmc.org/showpost.php?p=863492&postcount=6
Guessing that you're in the US, http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...0832900786 is an HP remote/receiver that will work with your Harmony.
JR
jhsrennie Wrote:http://forum.xbmc.org/showpost.php?p=863492&postcount=6
JR
You're fantastic, JR. Just ordered the item you suggested. Placed the order thru Amazon as I'm a Prime Member there and can get it delivered tomorrow for no extra charge. This is the item:
http://www.amazon.com/gp/product/B004PXJGXU
Sure hope it's the right one. Looks exactly like the one you linked me to on EBAY.
I'll post the results as soon as I test it out.
Thanks again.
