perhaps you should play around yourself as have i till you find the option that lets you disable buttons you dont want -.-'...ok ill tell you just press the backward/down key twice on the keyboard itll bring it up xD
p.s: a dharma prob? ...hardly -.-' perhaps you should ask angel over at the official adv thread here
http://forum.xbmc.org/showthread.php?tid=85724&page=276
hentai23 Wrote:perhaps you should play around yourself as have i till you find the option that lets you disable buttons you dont want -.-'....no im not gona tell you wich one anybody else?
Hentai
You constantly spam questions and start threads when people don't answer your questions. You biatch about everything that is released and go on about wanting to view your anime porn collection in different ways.
The one time, it would appear you can help someone, you stick out your tongue and say no, your not going to tell them.
Grow up !
You are a c*ck !
-.-' i edited my post you waz to quick to judge xD , was just a joke thou i was right someone would take it in the wrong way hence recheck my post ya noob yaharrrr xD
p.s: my "anime porn collection" is working fine btw thanks for asking xD
i sure as hell cant wait till this update for the favourites script comes out hell thats whats pissing me off atm -.-'
mattchapman Wrote:unfortunately I have the Advanced Launcher script installed and enabled but it does not show up when prompted to assign a program to the Addon menu. I can add Rom Collection Browser this way but for some reason Advanced Launcher is not an option.
Advanced Launcher is not a script, but a plugin. XBMC do not have any option (yet) to create a menu entry from plugins. You can bypass this limitation by adding Advanced Launcher as favourite, and then add create a menu entry from this favourite
Angelscry Wrote:Advanced Launcher is not a script, but a plugin. XBMC do not have any option (yet) to create a menu entry from plugins. You can bypass this limitation by adding Advanced Launcher as favourite, and then add create a menu entry from this favourite
Many thanks. I will experiment with favourites and try it this way.
ps - I'm surprised there is not more clear guidance on how to do this. Maybe I missed it somewhere. Thank god for the forums!
Hi Marcus, first.....great job!! It's thé most complete skin ever on XBMC, but what makes me go back to Aeon Nox everytime i try MQ3, is the lack of HD/big artist fanart (which is downloaded by CDart Manager) in the playback screen. And i don't mean the little pics with artist slideshow!! (that can be a nice addition as well ;-)) But The big fanart!
If you manage to do this in MQ3 then it's really really perfect! Artist logo in home and playback screen and random BIG fanart of the same artist!! Then you have a big show off at parties
Maybe it's posted before and yet answered but i get a zillion hits if i search on popular keywords!
Thx!
toineb Wrote:Hentai
lol. It's funny because it's true
I'm having problems starting movie trailers. When browsing through my movies it correctly shows that a trailer is available, but when pressing the arrow-down-key twice nothing happens (except for stating that the trailer is being activated or something). When using Aeon Nox this feature works without any problems. Am I missing something?
MarcosQui
In near future the Extrafanart Downloader will be replaced by the Artwork Downloader (EDEN11.0 version only).
It will support similar options like the logo-downloader currently has and more. Check my signature for more info. Once released to repo I will also put up a thread in skin development with more explanation for skin options.
Any idea when we'll see a fix to the Cast list within the information panel?
Like many others I am only able to see the first actor on the list and pressing down only returns to the lower set of menus.
Using Dharma.
Is "Run Automated Scan" working for anyone in Eden (11)?
as far as I can see it's broken in the latest version of this skin, I use this skin on 3 different machines, all of which have stopped auto updating the tv and movie folder!
just started one that had not been used in a while, and it auto updated, then the mq3 skin updated.. and I restarted xbmc, and autoupdate was unchecked!
and each time I check it, and restart it's unchecked!
any suggestions?
I don't think that can be caused by using a specific skin, what build of pre-eden are you using?
I'm using the latest one "XBMCSetup-20111112-a2f830e-master.exe", and I agree with you that it's a bit strange .. but as I wrote in the post, it worked - then the skin was updated, and the it stopped working!
so untill someone says otherwise, I have to point my finger at the skin, lol
also having it not work on 3 different machines, is a bit strange.. they all use the same skin, but not the same build xbmc.. since the skin auto updates, and xbmc does not!
