Yeah no worries. Here's a screenshot of my South Park TV directory for example.
clearart.png &
logo.png I get from fanart.tv and you need the logo-downloader addon to be able to use.
logo.png will be under the ClearLOGOs section on TV Shows page.
clearart.png - this is the icon that shows up in the Showart view.
logo.png - this is the icon for the, Panel Logo, view. Used also for having icons show up in bottom right on most other view as well.
All the other files I download off TVDB or create and edit myself:
banner.jpg - banner for the current TV Show.
fanart.jpg - background for the current TV Show
folder.jpg - main poster for the TV Show
landscape.jpg - for use in the Landscape, Panel Landscape and LandscapeX views
seasonxx.tbn - replace xx with the season no. like in my screen above for the season posters. Only one this doesn't work for is Season 0.
season-all.tbn - this is the, All Seasons, poster.
season-specials.tbn - this one is used for your, Specials, season poster (Season 0).
Then under this setup you need to enable these options in the Art section in skin options:
- Use 'landscape.jpg' for TV Series
- Use 'logo.png' and 'clearart.png' for TV Series
Also so banners show up properly when in the banner view. Bring up the side menu and change the banner setting from default to alternative. Banners should display correctly after this.
Hope this clears some of it up for you.
