2012-03-14, 11:17
(2012-03-14, 10:43)chippie Wrote: [ -> ](2012-03-14, 02:21)dars55 Wrote: [ -> ]
Try the below;
1. Come out of XBMC. rename your \userdata\Database\textures?.db file to .old then go back in and see if that has solved the issue.
2. Come out of XBMC, rename \userdata\guisettings.xml to .old then go back in. Doing ths will mean that you will have to configure the skin from scratch but it may solve the issue.
If neither of the above work then it may be that either the install or your thumbnails and the links have become corrupt. Either way I would probably suggest a clean build. unless of course someone else has any ideas.
EDIT: Cannot see your screen shots for some reason!
Thank you for the suggestions. I tried each fix and unfortunately I am still seeing the same behavior. It seems that my TV Shows artwork is damaged somehow. I have confirmed that what I am seeing displayed as fanart is actually banners, horizontals, clearart, logoart, posters... I am resigning myself to a fresh install as you suggested. I don't hold out hope for a fix as I found no mention of this after searching.
