(2012-04-16, 02:24)chippie Wrote: [ -> ][quote='sw2608' pid='1076641' dateline='1334475500']
Hi
I have been using MQ3 for a short time and hats off to all involved in it.
There is one issue which i am current having, and this is with the 'movie' section. All the movies that i browse through have the 'same' fanart image. I have tried everything that i can think of (even deleting and re-installing xbmc and Aeon), but am having no luck.
Any sugestions on how to fix this?
My system:
O/S Win 7 64bit
XBMC: Eden 11 RC2
Skin: Aeon MQ3 2.01
Regards
I assume you have tried this but just in case, bring up the side menu when in Movies, scroll to the BACKDROP section, select Mode and make sure that you have "DEFAULT" selected.
Failing that can you let us know exactly what fanart you have displayed, is it the delivered Movies backdrop? Do you store fanart locally with your movies? Do you use Artwork Downloader to download fanart for your movies?
The reason for the question about Artwork Downloader is due to the fact that I used it once to try to download some fanart, however, as I keep my fanart locally with my movies what Artwork Downloader did was to duplicate the fanart from one movie in a folder across all the other movies that did not have local fanart, so this may be similar to your issue if you use it, in which case you may have to go through your thumbnails folder and delete all duplicates or do a complete re-install remembering to disable the Movie fanart option under Artwork Downloader.
One thing to remember is that if you do not run XMBC in portable mode "xbmc.exe -p" it will create folders for your data on yout C: drive under your Program Data folder and am not sure if these folders are removed when you uninstall hence seeing the same issue after a reinstall if the thumbnails etc... have not been cleaned out.
I would recommend if you do not already, running XBMC in portable mode this keeps all files under the xbmc program folder, much easier to manage.
Hi Chippie
I have checked the side menu and in BACKGROUND/MODE, DEFAULT is selected.
Here are a couple of images so that you can see what is happening ...
http://imageshack.us/photo/my-images/19/...t011v.png/
http://imageshack.us/photo/my-images/641...t014j.png/
As can be seen, the background is the same in both pics.
In answer to your questions ...
no
yes - it is on
I am not sure where to go from here.
