Full Version: How to Unistall/Delete MTV Scraper
Is there any way to get rid of the MTV scraper. I dont use it anyway. I keep getting a msg that the addon it broken and wether i click Disable or No it keeps comming back.
I am using Apple TV2 & XBMC Eden-Pre
I have tried deleting the Folder in /private/var/mobile/Library/Preferences/XBMC/addons/metadata.mtv.com
is there anywhere else it may be looking that it thinks I still have it installed.
thanks
+1
I am also wondering if there is a remedy.
*Bump
Phixtit Wrote:+1
*Bump
I found out that when i made a backup of the databases and then put them back after mucking around i did not set the correct permissions and also read and write.
So every time XBMC started up , it checks the Database to see what version is logged. as it was read only it was not updateing and was not able to disable.
SSH into Xbmc and find where the DB's are stored , then rightclick then properties then make sure the write permisions are set and also set as Owner Mobile
hope this helps you...
