2011-08-18, 03:43
2011-08-18, 07:26
If you had a FAIL for the "Raw Read Error Rate" or a fail for any other value,
then you should be concerned and attempt to get the drive replaced if it is under warranty.
2011-08-18, 17:24
I did some research and from what I understand I should not worry about the #2 on the Raw Read... so just trying to get input. If I should just return this and get another.
