Full Version: [MAC]Launcher Addon doesn't execute .APP files[/MAC]
Hey guys!
I just installed XBMC (latest stable release) on my iMac, but I wanted to use Launcher. Unfortunately, Launcher on MAC only seems to recognize .exe files, since I can't execute .app files. Instead, it opens the .app as a folder (like an .app actually is.)
Is there a way to make Launcher run .app files instead of opening them like a folder?
Thanks in advance!
-NoidZ-
I think you need to select the executable file into the opened .app folder to start your application. .app files are not executable files, just a kind of archive with all the necessary files for the application inside. Other solution is to found how MacOSX start .app (i mean found the command line used under MacOSX to start a application only from its .app file).
