Full Version: "Remove from Library" Doesn't
Hi all,
Due to network stability issues I've copied my media from NAS to local storage and would like to remove all references to NAS media from my library.
I created new sources for the local content and first set the content type for the NAS sources to "None" then after the library was updated I deleted the NAS sources. The problem is movies on the NAS still show up in the library. I've tried using the context menu to delete them individually but it has no effect, the movies are still there.
How do I get XBMC to ignore all files on the NAS?
got your userdata/database folder and delete videos##.db ##=number
Worked like a charm.
your welcome
