Treviley: what platform are you on? it can't negotiate the ssl connection. I have seen the problem but it was because it didn't include python ssl support in the build.
Treviley: I see your build is from Jun 19 2011
could you upgrade to the current eden beta 2?
Bluecop: I have tried updating using Terminal and NitoTV and its telling me I have the latest version installed yet xbmc system info is still showing that my build is June 10, 2011.
Where am I going wrong?
ssh in as root and run these 2 commands
apt-get update
apt-get upgrade
You will have to press y to accept. It should get you to the latest version. Jan 20 is the compiled date of beta 2.
Thanks Bluecop. That worked. I can now access Amazon
Thanks again
I committed an update for 0.4.2
There are some minor code changes.
The main thing is the new databases for TV and Movies.
yea it doesn't get past the initial client digest. I have never seen this error before.
RTMP_Connect1, handshake failed
it is failing the handshake but I am not sure why.
No longer playing videos for me. Updated to Eden Beta 2, addon version 0.4.3. Log is at
http://pastebin.com/C11RvM6w
Everything seems to start going south at:
ERROR: RTMP_ReadPacket, failed to read RTMP packet header
followed by:
WARNING: could not find codec parameters for rtmpe
Any thoughts on the cause(s) ?
"drm":"FLASH_ACCESS"
unfortunately. It seem they are switching to flash access.
It is really weird because all the same videos still work perfectly for me. I don't know how they are determining who to send flash access to.
metheos: If you and anyone else having Flash Access problems could post your geographic location and the isp you have. I would like to try to track where it is occurring by location.
I also committed a 0.4.3 to fix some script errors on login and starting a video. It only occurred sometimes but should be fixed now
BlueCop Wrote:The heavy lifting is done by rtmpdump/librtmp. The plugin just provides xbmc a url for playback.
It is really easy to figure out if you proxy all your traffic including tsl/ssl. You get plain text versions of everything ussually. Once you have a log of the traffic then I just search for the rtmp:// link. It is just a matter of figuring out what is needed to get that link.
Amazon requires a cookie to show you are logged into the site. When you are logged in it sends you embedded flash variables in the html for prime video pages. The plug-in parses those variables which are used to make requests from amazon servers for the rtmp links of that video. There isn't a public api. It does seem to be an api though. There are a variety of events and requests you can post through it.
Thanks for the post, and sorry for the long silence. I was going to respond by asking, "So the video isn't encrypted, it's just protected access by cookie?" but then I read the subsequent few pages and see that it's getting encrypted with Flash
I really hope they don't kill your client.
not sure how to delete my multiple posts so just doing this instead.
