So... i got an AppleTV only to get XBMC... jailbroken it yesterday but today i am having a big problem... AppleTV keeps crashing and rebooting everytime i use XBMC... it crash on the menus and when playing movies.... usually i can't use XBMC for over 5minutes until it will crash
what did i do wrong ?
by the way, is it normal that i cant update AppleTV anymore after i installed XBMC ?
anarchoi Wrote:So... i got an AppleTV only to get XBMC... jailbroken it yesterday but today i am having a big problem... AppleTV keeps crashing and rebooting everytime i use XBMC... it crash on the menus and when playing movies.... usually i can't use XBMC for over 5minutes until it will crash
It's probably crashing because it's trying to update (which is bad. You don't want it to update itself because updating will erase jailbreaks)
Install update-be-gone from the Nito menu/options. If that alone doesn't stop it check out
http://forum.xbmc.org/showthread.php?tid=96685
Damn... i followed instructions in this guide:
http://www.sinfuliphone.com/showpost.php...ostcount=1
it was supposed to stop the crash but now i cant access anything.... it says "connection refused" when i try to access shared folder from my computer (but i can see everything when i browse, its weird)... Tryed re-entering my wifi login/pass but it doesnt work.....
I think i'm going to start from scratch again.... jailbreak and then follow again the official instructions
anarchoi Wrote:Damn... i followed instructions in this guide:
try restoring your /etc/hosts file first
