2011-08-22, 02:51
2011-08-22, 04:59
u loose nothing by trying but, 2GB should be enough by default,,,
2011-08-22, 09:30
Impossible to say with no information provided. It depends on how much mem that already is, which OS you run, which apps you use.. etc etc
2011-08-22, 18:03
For XBMC no.
2011-08-22, 21:08
LB06 Wrote:Impossible to say with no information provided. It depends on how much mem that already is, which OS you run, which apps you use.. etc etc
well i took in consideration that his question was about running XBMC
thats why i said, by default, he's got 2GB of ram in his HTPC,,,
it should already be enough,,,,
but i suggested him to allocate 512MB of ram to his Video,,,
im not sure he done that yet,,,
did you??
