ER1401 getting no sound under ubuntu.
I also got no sound under OPENElec but I fixed this using alsa mixer and changing the play device to 0,3. Therefore i think i know the problem for ubuntu since i presume its the same one... How can i go about fixing this? All the fixes I've read are long winded and its annoying when I think I know the problem only for the 93983983 step fixes not to work.
have you tried running alsaconf?
Sorry, i dont really know.
Did you both conf alsa and then activate (not unmute) the correct channels? I think its dont by pressing "X" on the channel while running alsamixer in a terminal
aarun@aarun-desktop:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 3: NVIDIA HDMI [NVIDIA HDMI]
Subdevices: 1/1
is what i have,.
i want it to play using card 0 device 3. help please!
i tried alsa 1.24 as u linked me to:
cp ../../alsa-kernel/include/ac97_codec.h .
patch -p0 -i ac97_codec.patch ac97_codec.h
make[4]: patch: Command not found
make[4]: *** [ac97_codec.h] Error 127
make[4]: Leaving directory `/opt/Alsa-1.0.24/alsa-driver-1.0.24/include/sound'
make[3]: *** [prepare] Error 2
make[3]: Leaving directory `/opt/Alsa-1.0.24/alsa-driver-1.0.24/include/sound'
make[2]: *** [prepare] Error 2
make[2]: Leaving directory `/opt/Alsa-1.0.24/alsa-driver-1.0.24/include'
make[1]: *** [dep] Error 1
make[1]: Leaving directory `/opt/Alsa-1.0.24/alsa-driver-1.0.24'
make: *** [include/sndversions.h] Error 2
* alsa-driver-1.0.24 make failed
Dunno what that is but did you sudo?
Any question related to the script is best answered on the thread on ubuntuforums
I fixed it thanks!!
new two problems: MCE remote infrared doesn't work + resolutoon when hooking up to TV is 1024.. it should be 1920
How did you fix it? I've been struggling with this for hours.
