Hi all
I have a question, I have my htpc set to standby after 10min. Now when I pause a movie is there a way to stop the pc going into standby as I not wan it to do this when I just pause a movie.
Any help thanks.
This doesn't behave this way for me (using OpenELEC OS) - paused keeps the HTPC from sleeping. Are you using Windows?
thanks
so this has been fixed in the newer versions of xbmc but i am using 10.1 and what file do i need to edit to fix it or is there a uipdate to 10.1 final
thanks
meridius Wrote:thanks
thanks
You'll have to apply the change and compile it on your own. There's no 10.1 update build.
thanks but dont know how to do that, might just wait untill the new version of xbmc for this fix.
thanks once again for the help
