Full Version: Change scraper w .nfo for specific files?
Hi All,
Is it possible to change the scraper to use for a specific movie using .nfo files?
I want to use TMDB by default _except_ for specific movies. I tried setting the default scraper to TMDB then created an .nfo file with just the Imdb link but no luck. Looks like it just tried searching TMDB using the Imdb ID.
I realize I can just create separate folders (1 per scraper), but I like all my movies being in the one directory.
"unfortunately" tmdb translates imdb urls. so that case in particular does not work unless you hack the scraper.
