2011-08-25, 14:31
Ok, in this thread: http://forum.xbmc.org/showthread.php?p=872414
I have talked about some of my problems with my remote.
First of all: BEFORE the update, my lirc and lircrc was working as it should. I could set the HTPC to sleep and wake it up with my remote. (the only thing that didn't work was my lircrc after sleep)
Now, since the update to Natty, I had to do A LOT of things.
One user in that thread linked me to this:
http://forum.xbmc.org/showthread.php?tid=104541
Since I had a fully working LIRC before, I wanted LIRC to handle everything also in Natty.
1. Let the kernel pass the signal through to LIRC
I still got all my lirc-files and Keymaps for XBMC working, so I don't need to talk about all those files.
I now had problem to wake the the HTPC up after a sleep.
In this thread: http://forum.xbmc.org/showthread.php?p=8...post835642
I could follow a guide and as you can see at one of the pictures above I've addes some info to the rc.local
Now I could wake the HTPC up after a sleep. But, my remote wasn't working.
In this thread, http://wiki.xbmc.org/index.php?title=Ubu...end_/_Wake
there is some info about what's causing this, and I did what it said.
The problem is, that it didn't work at all.
When I was looking around, I found an older version of that file, with an other solution for this problem:
I don't know what to do from here, and I hope that someone that KNOWS please can help me.
Should my "wake up" and "start xbmc from desktup" (lircrc) work better if I didn't used lirc at all?
/Söder
/Söder
