Full Version: Force TVDB Off - Use alternate Scraper
I was wondering how I could disable TVDB. The option to disable TVDB is greyed out and unavaliable.
I am attempting to scrape "Panty & Stocking With Garterbelt" and TVDB grabs the EN version which has each episode seperated into names (was released as multi-episodes I believe), I am trying to scrap the ANIDB version which has both names for each episode.
I am selecting the reload button and the only available option is the EN version, I'm assuming there is something wrong with my options but I cannot for the life of me figure it out.
Any help would be greatly appreciated Smile
ANIDB Episode List: http://anidb.net/perl-bin/animedb.pl?sho...e&aid=7529
TVDB Episode List: http://thetvdb.com/?tab=season&seriesid=...2011&lid=7
uhm, why would you disable the scraper? just select the other scraper in the set content dialog...
you can't disable cause it's shipped with the app. if you absolutely have to (your own risk!) delete the addon from the app dir.
Thanks a lot spiff Smile It's too late at might for my brain to think, was looking around in settings and trying to configure the scrapers the entire time.
Thanks Smile
spiff Wrote:uhm, why would you disable the scraper? just select the other scraper in the set content dialog...
Are you referring to when you add source and then "set content" ?
I only have one option for movies and the other for TV.
Is there another place or way to change scrapers?
You need to add another TV scraper via add-ons. Once that it done you will be able to select it when adding a new source.
stoli Wrote:You need to add another TV scraper via add-ons. Once that it done you will be able to select it when adding a new source.
Hmmm, I thought I had done this. I will have to re-check. Thanks.
