Done some searching on this and can't find a resolution.
Windows XP Pro sleep works fine when xbmc is not running, but wont sleep with xbmc running. Anybody got any suggestions ?
XBMC will prevent the computer from sleeping unless you configure the power savings options in XBMC.
CrystalP, is there any workaround for this? Why no option to use OS power management when XBMC is running? The problem is, when suspend is enabled in XBMC, it forces system stanby even if another process is configured to prevent from sleep. In my case, I'm using torrent client on the same PC and I want it to prevent standby if there are active torrents.
Howdy!
I'm on the boat too. My use-case: Sleep PC after 15 minutes when film is finished and I went to sleep.
But: If I let XBMC running, it caused PC sleep mode whenever I'm still working on it.
