2011-08-28, 19:22
I've got an xbmc live box, running on a sandy bridge Core i3, using on board HDMI output to the tv. I set this up using the guide found at http://forum.xbmc.org/showthread.php?tid=96669
Everything seems to be running well, except that I'm getting seemingly random crashes to a red screen that sort of looks like corrupted video or something. Here's a screenshot:
When this occurs, the box no longer accepts any input. If I have an ssh session open when this happens, the connection is lost as well. Only way out is to hard reboot using the physical power button on the box.
It seems to happen randomly. Sometimes I can watch 3 or 4 episodes without an issue, sometimes I only get 5 minutes between crashes. It has also happened while just idling on the home screen.
Here's an extract from the debug log file, though I'm not sure that it shows anything regarding the crash:
I've posted the full debug log on pastebin as well, since it wouldn't all fit in this post: http://pastebin.com/V8aj8cV6
Any ideas on what might be causing this, or possible resolutions?
Thanks, any help is greatly appreciated.
11:44:57 T:2624506736 DEBUG: CDVDPlayer::HandleMessages - player started 1
11:44:58 T:3044759904 INFO: CheckIdle - Closing session to http://xoap.weather.com (easy=0xa790d6f0, multi=0xadb1f328)
11:44:58 T:2574150512 DEBUG: CDVDPlayerAudio:: Discontinuity - was:1026754.088000, should be:1004925.728461, error:-21828.359539
11:44:59 T:3044759904 INFO: CheckIdle - Closing session to http://www.google.com (easy=0xa7900018, multi=(nil))
11:45:01 T:2582543216 DEBUG: CPullupCorrection: detected pattern of length 1: 33366.67, frameduration: 33366.666667
11:45:04 T:3044759904 DEBUG: LIRC: Update - NEW at 2269450:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:04 T:3044759904 DEBUG: OnKey: leftctrl (d0) pressed, action is VolumeUp
11:45:04 T:3044759904 DEBUG: ------ Window Init (DialogVolumeBar.xml) ------
11:45:04 T:3044759904 DEBUG: Alloc resources: 0.13ms (0.00 ms skin load)
11:45:05 T:3044759904 DEBUG: LIRC: Update - NEW at 2269684:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:05 T:3044759904 DEBUG: OnKey: leftctrl (d0) pressed, action is VolumeUp
11:45:05 T:3044759904 DEBUG: LIRC: Update - NEW at 2270051:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:05 T:3044759904 DEBUG: LIRC: Update - NEW at 2270418:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:06 T:3044759904 DEBUG: LIRC: Update - NEW at 2270719:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:06 T:3044759904 DEBUG: OnKey: leftctrl (d0) pressed, action is VolumeUp
11:45:06 T:3044759904 DEBUG: LIRC: Update - NEW at 2271453:000000037ff07bef 00 VolUp mceusb (VolUp)
11:45:08 T:3044759904 DEBUG: ------ Window Deinit (DialogVolumeBar.xml) ------
11:45:16 T:2905598832 DEBUG: ### [Qlock] - Delaying 240 secs
11:45:24 T:2926357360 DEBUG: Thread Jobworker 2926357360 terminating (autodelete)
11:45:24 T:2934750064 DEBUG: Thread Jobworker 2934750064 terminating (autodelete)
11:45:24 T:2863635312 DEBUG: Thread Jobworker 2863635312 terminating (autodelete)
11:45:24 T:2798492528 DEBUG: Thread Jobworker 2798492528 terminating (autodelete)
11:45:24 T:3044759904 DEBUG: LIRC: Update - NEW at 2289538:000000037ff07bf1 00 Mute mceusb (Mute)
11:45:24 T:3044759904 DEBUG: OnKey: launch_app1_pc_icon (c0) pressed, action is Mute
11:45:24 T:3044759904 DEBUG: ------ Window Init (DialogMuteBug.xml) ------
11:45:24 T:3044759904 DEBUG: Alloc resources: 0.14ms (0.00 ms skin load)
11:45:25 T:3044759904 DEBUG: LIRC: Update - NEW at 2290472:000000037ff07bf1 00 Mute mceusb (Mute)
11:45:25 T:3044759904 DEBUG: OnKey: launch_app1_pc_icon (c0) pressed, action is Mute
11:45:25 T:3044759904 DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
11:45:29 T:3044759904 DEBUG: SECTION:UnloadDll(libcurl-gnutls.so.4)
11:45:29 T:3044759904 DEBUG: Unloading: libcurl-gnutls.so.4
