Full Version: SMB on AppleTV1 ???
Does anyone know if SMB problem is fixed with the latest Nightly build (200110827) on AppleTV 1?
SMB broke after installing 20110824_Nightly Build. :mad:
Last good Nightly build was from 20110820 (everything worked).Big Grin
atv420
I am guessing nobody tried out latest Nightly build?
420
xbmc.log and syslog would be nice to see.
I currently downgraded to Dharma 10.1. Don't know how to downgrade to previous nightly build!
here is my XBMC log: (part I)
21:54:47 T:2684407808 M: 4042752 NOTICE: -----------------------------------------------------------------------
21:54:47 T:2684407808 M: 4005888 NOTICE: Starting XBMC, Platform: Mac OS X (8.8.2 i386). Built on Mar 9 2011 (Git:e9e9099)
21:54:47 T:2684407808 M: 4005888 NOTICE: special://xbmc/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
21:54:47 T:2684407808 M: 4009984 NOTICE: special://xbmcbin/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC
21:54:47 T:2684407808 M: 4005888 NOTICE: special://masterprofile/ is mapped to: /Users/frontrow/Library/Application Support/XBMC/userdata
21:54:47 T:2684407808 M: 4009984 NOTICE: special://home/ is mapped to: /Users/frontrow/Library/Application Support/XBMC
21:54:47 T:2684407808 M: 4005888 NOTICE: special://temp/ is mapped to: /Users/frontrow/.xbmc/temp
21:54:47 T:2684407808 M: 4034560 NOTICE: The executable running is: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/MacOS/XBMC
21:54:47 T:2684407808 M: 4030464 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log
21:54:47 T:2684407808 M: 4034560 NOTICE: -----------------------------------------------------------------------
21:54:47 T:2684407808 M: 4034560 NOTICE: Setup SDL
21:54:47 T:2684407808 M: 3067904 NOTICE: load settings...
21:54:47 T:2684407808 M: 2973696 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
21:54:47 T:2684407808 M: 2961408 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:54:47 T:2684407808 M: 2961408 NOTICE: loading special://masterprofile/guisettings.xml
21:54:47 T:2684407808 M: 3457024 NOTICE: Getting hardware information now...
21:54:47 T:2684407808 M: 3457024 NOTICE: Checking resolution 12
21:54:47 T:2684407808 M: 3325952 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:54:47 T:2684407808 M: 3276800 NOTICE: Loaded playercorefactory configuration
21:54:47 T:2684407808 M: 3293184 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:54:47 T:2684407808 M: 3293184 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:54:47 T:2684407808 M: 3289088 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml
21:54:47 T:2684407808 M: 3289088 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<skiploopfilter>8</skiploopfilter>
<osx_gl_fullscreen>true</osx_gl_fullscreen>
</advancedsettings>
21:54:47 T:2684407808 M: 3289088 NOTICE: Getting hardware information now...
21:54:47 T:2684407808 M: 3289088 NOTICE: Checking resolution 12
21:54:47 T:2684407808 M: 3289088 NOTICE: Default DVD Player: dvdplayer
21:54:47 T:2684407808 M: 3289088 NOTICE: Default Video Player: dvdplayer
21:54:47 T:2684407808 M: 3289088 NOTICE: Default Audio Player: paplayer
21:54:47 T:2684407808 M: 3276800 NOTICE: Loading media sources from special://masterprofile/sources.xml
21:54:49 T:2684407808 M: 2936832 NOTICE: GL_VENDOR = NVIDIA Corporation
21:54:49 T:2684407808 M: 2932736 NOTICE: GL_RENDERER = NVIDIA GeForce Go 7300 OpenGL Engine
21:54:49 T:2684407808 M: 2928640 NOTICE: GL_VERSION = 1.5 NVIDIA-1.4.60
21:54:49 T:2684407808 M: 2932736 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.10
21:54:49 T:2684407808 M: 2928640 NOTICE: GL_EXTENSIONS = GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_shading_language_100 GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_EXT_compiled_vertex_array GL_EXT_framebuffer_object GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_APPLE_pixel_buffer GL_NV_point_sprite GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_blend_square GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_vertex_program2_option GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
21:54:50 T:2684407808 M: 3031040 NOTICE: start dvd mediatype detection
21:54:50 T:2684407808 M: 2998272 NOTICE: initializing playlistplayer
21:54:50 T:2684407808 M: 2998272 NOTICE: DONE initializing playlistplayer
21:54:52 T:2684407808 M: 2899968 NOTICE: UpdateLibraries - Starting video library startup scan
21:54:52 T:51978240 M: 3092480 NOTICE: VideoInfoScanner: Starting scan ..
21:54:52 T:2684407808 M: 3080192 NOTICE: initialize done
21:54:52 T:2684407808 M: 3076096 NOTICE: Running the application...
21:54:52 T:2684407808 M: 3076096 NOTICE: Webserver: Starting...
21:54:53 T:2684407808 M: 3010560 NOTICE: WebServer: Started the webserver
21:54:53 T:2684407808 M: 2969600 NOTICE: ES: Starting event server
21:54:53 T:52001792 M: 2965504 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:54:53 T:52001792 M: 2965504 NOTICE: UDP: Listening on port 9777
21:54:53 T:2684407808 M: 2908160 NOTICE: starting zeroconf publishing
21:54:57 T:52214272 M: 3735552 NOTICE: -->Python Interpreter Initialized<--
21:54:57 T:52214272 M: 3723264 NOTICE: #########################################################################################
21:54:57 T:52214272 M: 3723264 NOTICE: Recently added script is no longer needed and the skins should remove dependencies for it
21:54:57 T:52214272 M: 3723264 NOTICE: https://github.com/xbmc/xbmc/commit/a61c...54e4494a22
21:54:57 T:52214272 M: 3723264 NOTICE: forum thread can be found at http://forum.xbmc.org/showthread.php?tid=99502
here is my XBMC log: (part II)
21:55:13 T:2684407808 M: 3989504 WARNING: GetLabel - Unknown nodetype requested 11
21:55:19 T:2684407808 M: 10481664 WARNING: GetLabel - Unknown nodetype requested 12
21:55:32 T:2684407808 M: 10903552 NOTICE: DVDPlayer: Opening: smb://xbmc:apple@DLINK-MEDIA/Multi-Media/Video/TV Shows/Entourage/Entourage - Season 3/Entourage - s03e15 - Manic Monday.avi
21:55:32 T:2684407808 M: 10952704 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:55:32 T:51968000 M: 10883072 NOTICE: Creating InputStream
21:55:33 T:51968000 M: 10256384 NOTICE: Creating Demuxer
21:55:34 T:51968000 M: 5169152 NOTICE: Opening video stream: 0 source: 256
21:55:34 T:51968000 M: 5165056 NOTICE: Creating video codec with codec id: 13
21:55:34 T:51968000 M: 4837376 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
21:55:34 T:51968000 M: 4841472 NOTICE: Creating video thread
21:55:35 T:51968000 M: 3870720 NOTICE: Opening audio stream: 1 source: 256
21:55:35 T:51968000 M: 3874816 NOTICE: Finding audio codec for: 86017
21:55:35 T:51968000 M: 3670016 ERROR: CDVDAudioCodecPassthroughFFmpeg::Open - FFmpeg SPDIF muxer does not support this codec
21:55:35 T:51968000 M: 3203072 NOTICE: Creating audio thread
21:55:35 T:54621184 M: 3194880 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
21:55:35 T:54621184 M: 3842048 NOTICE: Creating audio device with codec id: 86017, channels: 2, sample rate: 48000, no pass-through
21:55:35 T:54454784 M: 3325952 NOTICE: running thread: video_thread
21:55:35 T:54454784 M: 3092480 NOTICE: fps: 23.976000, pwidth: 672, pheight: 368, dwidth: 672, dheight: 368
21:55:35 T:54454784 M: 3059712 NOTICE: Display resolution DESKTOP : 720x480 @ 60.00 - Full Screen (12)
21:55:36 T:2684407808 M: 3186688 NOTICE: Using GL_TEXTURE_2D
21:55:36 T:2684407808 M: 3194880 NOTICE: GL: ARB shaders support detected
21:55:36 T:2684407808 M: 3063808 NOTICE: GL: Selecting Single Pass ARB YUV2RGB shader
21:55:36 T:2684407808 M: 3080192 NOTICE: GL: No vertex shader, fixed pipeline in use
21:55:36 T:2684407808 M: 3338240 NOTICE: GL: NPOT texture support detected
21:55:36 T:2684407808 M: 3354624 NOTICE: GL: Using GL_ARB_pixel_buffer_object
21:55:49 T:51978240 M: 16863232 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/4/42ea3650.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Chris Hemsworth\folder.jpg
21:55:49 T:51978240 M: 16859136 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/4/42ea3650.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/4/42ea3650.tbn>
21:55:49 T:51978240 M: 16879616 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/b/b26ca7a2.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Tom Hiddleston\folder.jpg
21:55:49 T:51978240 M: 16875520 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/b/b26ca7a2.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/b/b26ca7a2.tbn>
21:55:49 T:51978240 M: 16809984 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/c/c902deee.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Jaimie Alexander\folder.jpg
21:55:49 T:51978240 M: 16805888 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/c/c902deee.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/c/c902deee.tbn>
21:55:49 T:51978240 M: 16809984 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/8/8cdb6d50.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Rene Russo\folder.jpg
21:55:49 T:51978240 M: 16805888 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/8/8cdb6d50.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/8/8cdb6d50.tbn>
21:55:49 T:51978240 M: 16809984 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/5/5c80c91d.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Adriana Barraza\folder.jpg
21:55:49 T:51978240 M: 16805888 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/5/5c80c91d.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/5/5c80c91d.tbn>
21:56:02 T:51978240 M: 15773696 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://playon:playon@DLINK%2dMEDIA/Multi%2dMedia/Video/English/Total%20Recall%20%281990%29'
unix_err:'2' error : 'No such file or directory'
21:56:02 T:51978240 M: 15835136 ERROR: GetDirectory - Error getting smb://playon:playon@DLINK-MEDIA/Multi-Media/Video/English/Total Recall (1990)/
21:56:02 T:51978240 M: 15831040 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://playon:playon@DLINK%2dMEDIA/Multi%2dMedia/Video/English/Unstoppable%20%282010%29'
21:56:02 T:51978240 M: 15831040 ERROR: GetDirectory - Error getting smb://playon:playon@DLINK-MEDIA/Multi-Media/Video/English/Unstoppable (2010)/
21:56:33 T:52001792 M: 15417344 NOTICE: ES: Client from 127.0.0.1 timed out
21:56:43 T:51978240 M: 16093184 ERROR: CacheImage Unable to create new image special://masterprofile/Thumbnails/Video/e/ea984984.tbn from image C:\ProgramData\MediaBrowser\ImagesByName\People\Kay Kay Menon\folder.jpg
21:56:43 T:51978240 M: 16093184 ERROR: DeleteFile - cant delete file </Users/frontrow/Library/Application Support/XBMC/userdata/Thumbnails/Video/e/ea984984.tbn>. trying lower case </users/frontrow/library/application support/xbmc/userdata/thumbnails/video/e/ea984984.tbn>
21:56:48 T:51978240 M: 16285696 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://playon:playon@DLINK%2dMEDIA/Multi%2dMedia/Video/Hindi/Dhoka%20%282007%29'
21:56:48 T:51978240 M: 16285696 ERROR: GetDirectory - Error getting smb://xbmc:apple@DLINK-MEDIA/Multi-Media/Video/Hindi/Dhoka (2007)/
21:56:48 T:51978240 M: 16265216 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://playon:playon@DLINK%2dMEDIA/Multi%2dMedia/Video/Hindi/Hastey%20Hastey%20%28%29'
Xbmc log part III:
21:56:48 T:51978240 M: 16265216 ERROR: GetDirectory - Error getting smb://xbmc:apple@DLINK-MEDIA/Multi-Media/Video/Hindi/Hastey Hastey ()/
21:56:59 T:51978240 M: 17424384 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 02:06
22:17:23 T:2684407808 M: 16154624 NOTICE: CDVDPlayer::CloseFile()
22:17:23 T:2684407808 M: 16261120 NOTICE: DVDPlayer: waiting for threads to exit
22:17:23 T:51968000 M: 16261120 NOTICE: CDVDPlayer::OnExit()
22:17:23 T:51968000 M: 16261120 NOTICE: DVDPlayer: closing audio stream
22:17:23 T:51968000 M: 16261120 NOTICE: Closing audio stream
22:17:23 T:51968000 M: 16261120 NOTICE: Waiting for audio thread to exit
22:17:23 T:54621184 M: 16261120 NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:17:23 T:51968000 M: 16281600 NOTICE: Closing audio device
22:17:24 T:51968000 M: 16551936 NOTICE: Deleting audio codec
22:17:24 T:51968000 M: 16584704 NOTICE: DVDPlayer: closing video stream
22:17:24 T:51968000 M: 16580608 NOTICE: Closing video stream
22:17:24 T:51968000 M: 16584704 NOTICE: waiting for video thread to exit
22:17:24 T:54454784 M: 16560128 NOTICE: thread end: video_thread
22:17:24 T:51968000 M: 16576512 NOTICE: deleting video codec
22:17:24 T:51968000 M: 18366464 NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:17:24 T:51968000 M: 20758528 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:17:24 T:2684407808 M: 20787200 NOTICE: DVDPlayer: finished waiting
22:17:24 T:2684407808 M: 22269952 WARNING: GetLabel - Unknown nodetype requested 12
22:17:25 T:2684407808 M: 14192640 NOTICE: CDVDPlayer::CloseFile()
22:17:25 T:2684407808 M: 14192640 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:17:25 T:2684407808 M: 14192640 NOTICE: DVDPlayer: waiting for threads to exit
22:17:25 T:2684407808 M: 14192640 NOTICE: DVDPlayer: finished waiting
22:17:25 T:2684407808 M: 16662528 WARNING: GetLabel - Unknown nodetype requested 12
22:17:43 T:2684407808 M: 15245312 NOTICE: DVDPlayer: Opening: smb://xbmc:apple@DLINK-MEDIA/Multi-Media/Video/TV Shows/Entourage/Entourage - Season 3/Entourage - s03e16 - Gotcha!.avi
22:17:43 T:2684407808 M: 15376384 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:17:43 T:55030272 M: 15368192 NOTICE: Creating InputStream
22:17:43 T:55030272 M: 14794752 NOTICE: Creating Demuxer
22:17:44 T:55030272 M: 11853824 NOTICE: Opening video stream: 0 source: 256
22:17:44 T:55030272 M: 11870208 NOTICE: Creating video codec with codec id: 13
22:17:44 T:55030272 M: 11866112 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
22:17:44 T:55030272 M: 11870208 NOTICE: Creating video thread
22:17:44 T:55030272 M: 11862016 NOTICE: Opening audio stream: 1 source: 256
22:17:44 T:55030272 M: 11866112 NOTICE: Finding audio codec for: 86017
22:17:44 T:55030272 M: 11845632 ERROR: CDVDAudioCodecPassthroughFFmpeg::Open - FFmpeg SPDIF muxer does not support this codec
22:17:44 T:55030272 M: 11833344 NOTICE: Creating audio thread
22:17:44 T:53462016 M: 11825152 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
22:17:44 T:53460992 M: 11829248 NOTICE: running thread: video_thread
22:17:44 T:53462016 M: 11812864 NOTICE: Creating audio device with codec id: 86017, channels: 2, sample rate: 48000, no pass-through
22:17:44 T:53460992 M: 10694656 NOTICE: fps: 23.976000, pwidth: 672, pheight: 368, dwidth: 672, dheight: 368
22:17:44 T:53460992 M: 8032256 WARNING: CRenderManager::Configure - timeout waiting for previous frame
22:17:44 T:53460992 M: 8048640 NOTICE: Display resolution DESKTOP : 720x480 @ 60.00 - Full Screen (12)
22:17:44 T:53462016 M: 7626752 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:17:45 T:2684407808 M: 2822144 NOTICE: Using GL_TEXTURE_2D
22:17:45 T:2684407808 M: 2875392 NOTICE: GL: ARB shaders support detected
22:17:45 T:2684407808 M: 2879488 NOTICE: GL: Selecting Single Pass ARB YUV2RGB shader
22:17:45 T:2684407808 M: 2875392 NOTICE: GL: No vertex shader, fixed pipeline in use
22:17:45 T:2684407808 M: 2854912 NOTICE: GL: NPOT texture support detected
22:17:45 T:2684407808 M: 2859008 NOTICE: GL: Using GL_ARB_pixel_buffer_object
22:18:43 T:52001792 M: 17833984 NOTICE: ES: Client from 127.0.0.1 timed out
22:46:56 T:2684407808 M: 18014208 NOTICE: CDVDPlayer::CloseFile()
22:46:56 T:2684407808 M: 18014208 NOTICE: DVDPlayer: waiting for threads to exit
22:46:56 T:55030272 M: 18014208 NOTICE: CDVDPlayer::OnExit()
22:46:56 T:55030272 M: 18014208 NOTICE: DVDPlayer: closing audio stream
22:46:56 T:55030272 M: 18014208 NOTICE: Closing audio stream
22:46:56 T:55030272 M: 18014208 NOTICE: Waiting for audio thread to exit
22:46:56 T:53462016 M: 18014208 NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:46:56 T:55030272 M: 18071552 NOTICE: Closing audio device
22:46:56 T:55030272 M: 18141184 NOTICE: Deleting audio codec
22:46:56 T:55030272 M: 18173952 NOTICE: DVDPlayer: closing video stream
22:46:56 T:55030272 M: 18169856 NOTICE: Closing video stream
22:46:56 T:55030272 M: 18173952 NOTICE: waiting for video thread to exit
22:46:56 T:53460992 M: 18153472 NOTICE: thread end: video_thread
22:46:56 T:55030272 M: 18169856 NOTICE: deleting video codec
22:46:56 T:55030272 M: 20164608 NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:46:56 T:55030272 M: 23080960 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:46:56 T:2684407808 M: 23121920 NOTICE: DVDPlayer: finished waiting
22:46:57 T:2684407808 M: 24784896 WARNING: GetLabel - Unknown nodetype requested 12
22:46:57 T:2684407808 M: 16695296 NOTICE: CDVDPlayer::CloseFile()
22:46:57 T:2684407808 M: 16695296 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:46:57 T:2684407808 M: 16695296 NOTICE: DVDPlayer: waiting for threads to exit
22:46:57 T:2684407808 M: 16695296 NOTICE: DVDPlayer: finished waiting
22:46:57 T:2684407808 M: 17915904 WARNING: GetLabel - Unknown nodetype requested 12
22:46:59 T:2684407808 M: 17960960 WARNING: GetLabel - Unknown nodetype requested 11
22:47:04 T:56060416 M: 11206656 NOTICE: -->Python Interpreter Initialized<--
22:47:04 T:56060416 M: 11198464 NOTICE: #########################################################################################
22:47:04 T:56060416 M: 11198464 NOTICE: Recently added script is no longer needed and the skins should remove dependencies for it
22:47:04 T:56060416 M: 11198464 NOTICE: https://github.com/xbmc/xbmc/commit/a61c...54e4494a22
22:47:04 T:56060416 M: 11198464 NOTICE: forum thread can be found at http://forum.xbmc.org/showthread.php?tid=99502
22:47:08 T:2684407808 M: 20484096 NOTICE: Storing total System Uptime
22:47:08 T:2684407808 M: 20500480 NOTICE: Saving settings
22:47:08 T:2684407808 M: 20488192 NOTICE: stop all
22:47:08 T:2684407808 M: 20500480 NOTICE: ES: Stopping event server
22:47:08 T:2684407808 M: 20484096 NOTICE: stopping zeroconf publishing
22:47:08 T:2684407808 M: 20480000 NOTICE: Webserver: Stopping...
22:47:08 T:2684407808 M: 20529152 NOTICE: WebServer: Stopped the webserver
22:47:08 T:2684407808 M: 20529152 NOTICE: Webserver: Stopped...
22:47:09 T:52001792 M: 20606976 NOTICE: ES: UDP Event server stopped
22:47:09 T:2684407808 M: 20611072 NOTICE: stop dvd detect media
22:47:09 T:2684407808 M: 20623360 NOTICE: stop sap announcement listener
22:47:09 T:2684407808 M: 20627456 NOTICE: clean cached files!
22:47:09 T:2684407808 M: 20623360 NOTICE: unload skin
22:47:09 T:2684407808 M: 24260608 NOTICE: stop python
22:47:09 T:2684407808 M: 34091008 NOTICE: stopped
22:47:09 T:2684407808 M: 34091008 NOTICE: destroy
22:47:09 T:2684407808 M: 34086912 NOTICE: unload sections
Built on Mar 9 2011 (Git:e9e9099), this does not match your initial post and is useless for me to look at. "SMB broke after installing 20110824_Nightly Build".
if you downgraded, I bet userdata needs a nuking.
And please, use http://www.pastebin.com next time.
davilla Wrote:if you downgraded, I bet userdata needs a nuking.
how would I go about nuking the userdata?
I am able to get to my frontrow (appletv1) through 'cyberduck'.
Thanks,
atv420
Any help to nuking userdata?
do i simply delete the 'Userdata' file?
Thanks,
ATV420
yeah, just delete the userdata folder
