t0mm0 Wrote:yeah, please do, as long as it's generic enough that you can pass anything around - maybe it will be useful in other situations too.
t0mm0
Will do, I created a fork for myself and will put in this change as well as my Zshare plugin
Eldorado Wrote:Will do, I created a fork for myself and will put in this change as well as my Zshare plugin
great! look forward to the pull request
i promise i will try and fix the sorting (and videoid) stuff this weekend
t0mm0
Eldorado, have you played around with any of the metadata yet?
rogerthis Wrote:Eldorado, have you played around with any of the metadata yet?
I have, but nothing substantial yet..
I grabbed the latest from the Icefilms master branch, moved it into it's own script folder all setup to be it's own script addon
The fun part now is stripping all Icefilms specific coding as well as some items that were left on their to-do list
I was wondering if I should throw it up on my git repository for all to start working on, or pass it over to t0mm0 to host as he seems to have a much better understanding of python..?
Also, seems that it can only scrape tmdb and tvdb using IMDB id's.. would need to add in scraping based on just movie or tv show name, not sure how difficult it will be to add that in
Eldorado Wrote:I was wondering if I should throw it up on my git repository for all to start working on, or pass it over to t0mm0 to host as he seems to have a much better understanding of python..?
haha
but thanks for the compliment
by all means bung it up on github so everyone can take a look. personally i probably won't get to it for a while
i'm really trying to nail the video id stuff whch is turning out to be more complicated than i first hoped (i've already completely rewritten everything several times but am never happy with it as it ends up too complicated) once that is done and people are happy i think we should do some kind of release so people can actually use all this stuff!
t0mm0
Eldorado Wrote:I have, but nothing substantial yet..
Yeah, could you throw it up on your git, and I'll take a look at it and see what I can do. The plan is either add it to the t0mm0 repo or keep it separate. I guess it all depends on how big it gets. Could you start a new thread for it too?
We would need to make a plan on how it will function. eg Will the info get added to the library, or have a cache for each addon, or it gets redone at each page load.
Metadata for favourites only might be a good idea. Where your favourites would get reloaded at addon start \ xbmc reboot.
rogerthis Wrote:Yeah, could you throw it up on your git, and I'll take a look at it and see what I can do. The plan is either add it to the t0mm0 repo or keep it separate. I guess it all depends on how big it gets. Could you start a new thread for it too?
Well unless I'm reading the code wrong, and it's also an area of xbmc/python I have not gone yet, it appears it creates a database or container (if that's the correct term) in the userdata directory to store all meta data, then references/adds to it as you navigate Icefilms
So my first thought would be to have a central meta data DB that all addons reference and update
I'll pop this up on my repository tonight so people can start taking a look
Need a bit of help on this one..
This page is giving me some issues regarding ascii characters being used, likely the same error some complain about in Icefilms:
http://www.free-tv-video-online.me/inter...son_4.html
13:22:10 T:4732 ERROR: Error Type: <type 'exceptions.UnicodeEncodeError'>
13:22:10 T:4732 ERROR: Error Contents: 'ascii' codec can't encode character u'\x92' in position 6: ordinal not in range(128)
13:22:10 T:4732 ERROR: Traceback (most recent call last):
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\plugin.video.projectfreetv\default.py", line 310, in <module>
addon.add_video_item(url,{'title':name},{'section': 'tvshows', 'video': name})
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 560, in add_video_item
playlist, item_type='video')
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 535, in add_item
play = self.build_plugin_url({'play': play}) + self.build_url_query(queries)
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 211, in build_url_query
return '&' + urllib.urlencode(queries)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib.py", line 1269, in urlencode
v = quote_plus(str(v))
UnicodeEncodeError: 'ascii' codec can't encode character u'\x92' in position 6: ordinal not in range(128)
13:22:10 T:4732 INFO: -->End of Python script error report<--
I'm guessing it's the single quote mark in the episode - "3. If You Love Me, Why Am I Dyin'?"
I've tried adding a .encode('utf-8') from some google searches, but doesn't get any better:
13:37:30 T:6680 ERROR: Error Type: <type 'exceptions.UnicodeDecodeError'>
13:37:30 T:6680 ERROR: Error Contents: 'ascii' codec can't decode byte 0xc2 in position 19: ordinal not in range(128)
13:37:30 T:6680 ERROR: Traceback (most recent call last):
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\plugin.video.projectfreetv\default.py", line 309, in <module>
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 546, in add_item
self.log_debug('adding item: %s - %s' % (infolabels['title'], play))
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 283, in log_debug
self.log(msg, xbmc.LOGDEBUG)
File "C:\Users\M33282\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib\t0mm0\common\addon.py", line 260, in log
msg = unicodedata.normalize('NFKD', unicode(msg)).encode('ascii',
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 19: ordinal not in range(128)
13:37:30 T:6680 INFO: -->End of Python script error report<--
Eldorado Wrote:Need a bit of help on this one..
Have you tried Anarchintosh's htmlcleaner.py?
https://github.com/icefilms-xbmc/htmlcle...cleaner.py This is what icefilms used to remove those annoying characters. It would be useful to be in t0mm0's resolver.
rogerthis Wrote:Have you tried Anarchintosh's htmlcleaner.py? https://github.com/icefilms-xbmc/htmlcle...cleaner.py This is what icefilms used to remove those annoying characters. It would be useful to be in t0mm0's resolver.
actually, it looks like this is a bug in the web site rather than my code (but i would say that wouldn't i
the page says that is is using the ISO-8859-1 character set, but \x92 is not a valid ISO-8859-1 character (looks like it is really CP-1252). maybe we should add an override in t0mm0.common.net where if you know that the web page is lying about the character set you can specify it?
re: htmlcleaner.py - all the functionality i think is useful is already available in t0mm0.common.addon (though the list of entities could do with being expanded!). generally where possible my code is trying to preserve all weird characters because what is a weird character to me might be important in someone elses language. we should not be stripping stuff, we should be making sure it is proper utf-8 unicode instead. if the web page identifies the correct character set in either the http header or a meta tag then this should already happen - the problem only occurs at the moment when the web page lies
t0mm0
t0mm0 Wrote:actually, it looks like this is a bug in the web site rather than my code (but i would say that wouldn't i )
t0mm0
I might be in a bit of a catch then, it seems to be just this one page on the site that is giving me this issue.. and I think it's rather recent as I know I've pulled in the page before
If I switch the character set being used to satisfy this one page, I could likely break the others? How do you change the character set when requesting a page?
hi eldorado,
Eldorado Wrote:I might be in a bit of a catch then, it seems to be just this one page on the site that is giving me this issue.. and I think it's rather recent as I know I've pulled in the page before
well in this case i believe that ISO-8859-1 is a subset of CP1252 so it might actually be worth forcing CP1252 on any page that says it is ISO-8859-1 just in case (unless someone who knows more about this stuff than me has a better suggestion?) which we could do in t0mm0.common.net
i would think it is likely that all pages on a site would be encoded the same way so if you forced an encoding it would be okay across the whole site, although of course i could be wrong....
Eldorado Wrote:How do you change the character set when requesting a page?
you can't at the moment, but i was thinking maybe adding something like a force_page_encoding argument to http_GET() might be useful?
t0mm0
t0mm0 Wrote:hi eldorado,
t0mm0
I'm thinking it could be, we could use this one page as a solid test
