Full Version: handling parsed Hebrew string.
Hi.
In this code segment for parsing http://www.mako.co.il/mako-vod-index:
soup = BeautifulStoneSoup(link, convertEntities=BeautifulStoneSoup.XML_ENTITIES)
    programs = soup('ul')
    for i,prog in enumerate(programs):
        if i==(4+getLetterValue(name)):
            j = 0
            while j < len(prog('li')):
                li = prog('li')[j]
        link = li('a')[0]
        url = link['href']
                text = link.contents
                print ''.join(text)
                j = j+1
The result is unicode code and not hebrew character. when reading the log file, or adding a string I have generated using join to a directory I see
[u'\u05ea\u05d0\u05de\u05d9\u05df \u05dc\u05d9']
and not the Hebrew text I want.
How to fix this?
yotama9 Wrote:Hi.
            j = 0
                li = prog('li')[j]
        link = li('a')[0]
        url = link['href']
                print ''.join(text)
                j = j+1
How to fix this?
it already is a unicode string. you may need to encode it to utf-8
>>> print u'\u05ea\u05d0\u05de\u05d9\u05df \u05dc\u05d9'.encode('utf-8')
תאמין לי
once again, t0mm0 to the rescue.
