Full Version: The Double Tap
It's what I call it when you get two of the same movie tag on one movie. Oo
So far it has done Assassins (1997), Transformers, and X-Men Origins: Wolverine.
I've double checked the file library for duplicate copies, removed both the tag and movie file from the library, and put the file back in.... I get the same two tags on the same movie. Is there a way to fix this problem? It is becoming tedious to remove the excess tag... only to have it return the second the system does an IMDB update. Confused
