Apple TV 2 now running great apart from...
Silly Mistake - I've removed the settings icon on Alaska Skin and have no way of bringing settings back. Is there a quick fix?
I was intending to use my bluetooth keyboard to access it however I didn't have the keyboard option ticked. My cursors etc are working with the bluetooth however nothing else. The "s" key is turning xbmc off...
This is causing a headache...
Rob Xbox User Wrote:Apple TV 2 now running great apart from...
Download it from hitcher's repo and put it back again? Or is this way too simple?
I think switching to another skin and switching back will undo skin specific changes. Failing that you could delete guisettings.xml
Ned Scott Wrote:I think switching to another skin and switching back will undo skin specific changes. Failing that you could delete guisettings.xml
nope he is going to have to delete guisettings.xml or edit it
btw number one reason I don't let people remove that button in any of my skins
Had to delete guisettings and start again...
It's odd my keyboard links up fine with xbmc on apple tv 2. however s issues a shutdown command rather than settings - it doesn't seem to be able to issue any other commands other than the currsors and back (delete).
[quote=Rob Xbox User]Had to delete guisettings and start again...
Hi, could you please tell me where guisettings file is located at ATV2? I have to reset the skin as well, but fail to find it...
Thanx a lot
challenger Wrote:[quote=Rob Xbox User]Had to delete guisettings and start again...
Thanx a lot
/private/var/mobile/Library/Preferences/XBMC/userdata
Dixon Butz Wrote:[quote=challenger]
Dixon, thanx a lot, you saved my day :-)
