2011-09-01, 09:44
Hello,
after several evening trying around I end up here and need to ask for some help.
I have an iMac on which I run XBMC. In my Network is also a Synology Diskstation (411j) where I store all my files. This is connected and also implemented in my Explorer. So I can use my vids from it like they would be on my hard disk. Also time mashine working on that.
First I just set up the media Server with upnp. That worked, but while playing HD MKV movies xbmc give out some weird noises every maybe 2 seconds (tried with large and small mkv movies all the same). All is Gigabit LAN so should not be a problem with that. I wanted to try now to connect via normal network access. But nowhere in XBMC I can find my network storage. If I try NFS I can see its IP but not open or add. SMB says "no shares".
Ron
So....how to connect? Or solve the sound problem.?
Ron
