Full Version: No TV Logo?
Hello
I have no TV Logo in TV Show Fanart view.
I have downloaded the logos via the script and it showed
Downloaded: 45
Found: 0
There are logo.png in each and every tv show folder.
The TV Guide shows logos...
I have tried deleting all logos and downloading them again.
The log shows nothing really:
[HTML]21:36:11 T:140458273601632 M:3772010496 WARNING: Skin has invalid include: PosterWrapView2_Fanart
21:36:11 T:140458273601632 M:3772387328 WARNING: Previous line repeats 13 times.
21:36:11 T:140458273601632 M:3772387328 WARNING: Skin has invalid include: Episode_Next_Aired
21:36:11 T:140458273601632 M:3772387328 WARNING: Previous line repeats 1 times.
21:36:11 T:140458273601632 M:3772387328 WARNING: Skin has invalid include: frame_flags
21:36:11 T:140458273601632 M:3772387328 WARNING: Previous line repeats 2 times.
21:36:11 T:140458273601632 M:3772387328 WARNING: Skin has invalid include: "Poster_Next_Aired"
21:36:12 T:140458273601632 M:3772387328 WARNING: Previous line repeats 1 times.
21:36:12 T:140458273601632 M:3772387328 WARNING: Skin has invalid include: frame_flags
21:36:12 T:140458273601632 M:3772334080 WARNING: Previous line repeats 2 times.
21:36:12 T:140458273601632 M:3772334080 ERROR: Python script "script.tvtunes" does not exist
[/HTML]
Any ideas? Please!
post a full debug log to pastebin.com
I haven't been able to download logos for a while, either. Whether I use the script to download all logos from the system settings or download individually from the TV show info, I get nothing. When downloading individually, the download seems to work, but I get an "Error copying file" error. I thought it might be a permissions issue since the shows are on a SMB share, but I set the permissions to full access for everyone, and it still doesn't work.
hegemon13 Wrote:I haven't been able to download logos for a while, either. Whether I use the script to download all logos from the system settings or download individually from the TV show info, I get nothing. When downloading individually, the download seems to work, but I get an "Error copying file" error. I thought it might be a permissions issue since the shows are on a SMB share, but I set the permissions to full access for everyone, and it still doesn't work.
I allso have my shows on a SMB share, but the logos are downloaded there anyway without any problems... but they arent readed!
Debug log.
stoli Wrote:Debug log.
Here is the log: (Couldnt fit in pastebin)
http://dl.dropbox.com/u/2159489/xbmc.log
Of course all the folders that are scanned is not "real".
The real part starts at line 9079
ls in the True Blood folder (mounted), which i dont do automaticly. xbmc i suppose to read from smb.
xbmc@ulra:/media/Lager/Serier/True Blood$ ls
logo.png                                    True.Blood.S03E03.720p.HDTV.x264-IMMERSE           True.Blood.S03E07.720p.HDTV.x264-IMMERSE
True.Blood.S03E01.720p.HDTV.X264-DIMENSION  True.Blood.S03E04.PROPER.720p.HDTV.x264-IMMERSE    True.Blood.S03E08.720p.HDTV.x264-IMMERSE
True.Blood.S03E02.720p.HDTV.x264-IMMERSE    True.Blood.S03E06.PROPER.720p.HDTV.X264-DIMENSION  True.Blood.S03E09.720p.HDTV.x264-IMMERSE
It won't load the images on the smb path:
DEBUG: GetImageHash - unable to stat url smb://DISKMASKINEN/lager2/Serier/Two And A Half men/logo.png
You may want to check here: http://forum.xbmc.org/showthread.php?p=8...post871131
I figured it had to do something with the credentials, but didnt find any solution.
Appreciated your help!
I figured out my issue, and I'll post the solution for anyone else who encounters it. Windows 7 SMB sharing is a bit clunky. Adding full permissions for "Everyone" in the advanced sharing properties does not actually provide write access to the folder from another system by itself. You also have to enable the Guest account on the machine.
