2011-09-02, 11:48
Hello, this is my first post here. I was recently introduced to xbmc by a friend and I absolutely love it. Love it! However, after following guides and setting up everything I have run into a few issues that I need help with. I am not sure what the causes are so I'll attempt to provide a thorough explanation of how everything is set everything up to make it easier to understand. If you want to view the issues right away, skip down to Issues. Also, if anything is unclear please point it out.
My media setup:
Both computers runs Windows 7. The first computer is the main downloading server that shares network folders. The folders contains TV Shows and Movies spread on two disk drives (Downloads1 & Downloads2). All the video files are compressed as .rar files and are organized in folders according to standard naming conventions. They only contain .iso, .img, .mkv and .avi files.
Due to sharing rules set by the utilized downloading source there's a requirement to organize Movies and TV Shows first by type (720p / 1080p / DVDR / Series) and then by Sample / NoSample folders which contains all the movie releases (Sample folders is not enforced for series). (In case you're wondering why - the samples are used for practical reasons, mainly to determine the quality of a release by downloading a single file of smaller size, instead of the whole movie release. It has to be this way and cannot be changed.)
A few examples of how the library is organized:
DVDR - Sample
- Downloads2\DVDR\Sample\A-DVDR-Movie-Folder\[rar files]
DVDR - NoSample
- Downloads2\DVDR\NoSample\A-DVDR-Movie-Folder\[rar files]
720p - Sample
- Downloads2\720p\Sample\A-720p-Movie-Folder\[rar files]
720p - NoSample
- Downloads2\720p\NoSample\A-720p-Movie-Folder\[rar files]
1080p (Sample & NoSample) is the same as above.
Series
- Downloads1\Series\A-Series-Folder\Season.01\A-Episode-Release-Folder\[rar files]
The second computer is a laptop connected to the same network with access to the shared folders and is running xbmc v10.1.
Issues
- First issue
When updating the library for TV Shows for the first time I did the following:
Right clicked the folder "Series" - Set Content - Check "Run automated scan" - OK
Everything is perfect.
I proceeded doing this for DVDR
Right clicked the folder "DVDR" - Set Content - Check "Run automated scan" and "Use folder names for lookups" - OK
This time nothing happened, and I realize it was probably caused by the subfolders Sample and NoSample. Now, the problem is that when I follow the same procedure on the NoSample folder it works perfectly, but not on the Sample folder. I don't understand why. It is the same with 720p and 1080p. The movies contained in the "Sample" folders are not added, only movies from "NoSample".
Answer - Any folders named "Sample" are excluded from search. Thus, having all movies contained in a folder named "Sample" will produce no result when attempting to update library.
-Second issue
A folder named like this
SeriesName.E01.720p.HDDVD.x264
does not follow the standard naming convention as it has no s01 in the name. This is probably done because there is only one season. Because of this the episodes are not automatically added to the library, only the main folder. How can the episodes be added to the library properly? Changing the folder name is not an option.
Answer - Modify regex, see post #5
-Third issue
If "Update library on startup" is checked, two empty series that does not exist are added. Is there any way to check what files have triggered the adding of a series?
I greatly appreciate any help and feedback. If anything is unclear please point it out and I'll attempt to improve it. If you want screenshots I can provide that as well.
Answer - see post #5
-BlueBottle
My media setup:
DVDR - Sample
DVDR - NoSample
720p - Sample
720p - NoSample
Series
Issues
- First issue
-Second issue
-Third issue
-BlueBottle
