Please can you help undertsand why the search results is not playable.
https://paste.kodi.tv/hujuciyapi
Played through Confluence skin
16:00:25.443 T:139990879708928 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:00:41.399 T:139993566543168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2203&mode=play&id=6900b2613994dcb3d39aff5f8f7bd73a&filename=Mad+Max+%281979+%29.mkv]
16:00:42.954 T:139990710597376 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:00:58.847 T:139993566543168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2204&mode=play&id=572b61ad1923223603d8e8fc41945e52&filename=Mad+Max+2+-+The+Road+Warrior+%281981%29.mkv]
16:01:03.159 T:139990871316224 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:01:21.394 T:139993566543168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2205&mode=play&id=65e7678965544e67319b2878fc2d854a&filename=Mad+Max+Beyond+Thunderdome+%281985%29+.mp4]
16:01:21.704 T:139990710597376 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:01:33.759 T:139993566543168 NOTICE: Previous line repeats 2 times.
16:01:33.759 T:139993566543168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2206&mode=play&id=31c8779e16d503879bb1bde17829e566&filename=Mad+Max+-+Fury+Road+%282015%29.mkv]
16:01:37.213 T:139990829356800 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:01:38.253 T:139990804182784 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:01:49.074 T:139993566543168 ERROR
https://paste.kodi.tv/akuzumutox
Played through Estuary Skin
16:12:19.918 T:140231851747072 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:12:47.958 T:140234736176448 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2203&mode=play&id=6900b2613994dcb3d39aff5f8f7bd73a&filename=Mad+Max+%281979+%29.mkv]
16:12:50.554 T:140231851747072 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:12:56.636 T:140234736176448 NOTICE: Samba is idle. Closing the remaining connections
16:13:02.224 T:140234736176448 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2204&mode=play&id=572b61ad1923223603d8e8fc41945e52&filename=Mad+Max+2+-+The+Road+Warrior+%281981%29.mkv]
16:13:05.117 T:140231923713792 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:13:07.442 T:140231915321088 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:13:26.848 T:140234736176448 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2205&mode=play&id=65e7678965544e67319b2878fc2d854a&filename=Mad+Max+Beyond+Thunderdome+%281985%29+.mp4]
16:13:28.117 T:140231923713792 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:13:44.732 T:140234736176448 NOTICE: Previous line repeats 1 times.
16:13:44.732 T:140234736176448 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2206&mode=play&id=31c8779e16d503879bb1bde17829e566&filename=Mad+Max+-+Fury+Road+%282015%29.mkv]
16:13:48.399 T:140231915321088 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:13:48.423 T:140233811461888 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:13:50.285 T:140231873361664 NOTICE: Previous line repeats 1 times.
16:13:50.285 T:140231873361664 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:14:03.414 T:140234736176448 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.emby.movies/?dbid=2254&mode=play&id=d150fbb9006f0ac84329bd3623fb15cb&filename=Max+Payne+%282008%29.mp4]
16:14:07.182 T:140233811461888 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
16:14:07.940 T:140231923713792 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
