Hehe actual startup won't work
If you have multiple profiles and you boot to login screen you have no library connected at that time.
So it should be 'login'
(2012-03-25, 14:59)Martijn Wrote: [ -> ]Hehe actual startup won't work
i thought Login was processed before Startup ?
* ronie adds another item to his list of things to test
(2012-03-25, 15:01)ronie Wrote: [ -> ] (2012-03-25, 14:59)Martijn Wrote: [ -> ]Hehe actual startup won't work
Had the same with AD. If you start it at start="startup" then it can't scan the library for items because there isn't one. This doesn't matter when you only have one profile and never use the login screen.
(2012-03-25, 15:04)Martijn Wrote: [ -> ]Nope. Had the same with AD. If you start it at start="startup" then it can't scan the library for items because there isn't one. This doesn't matter when you only have one profile and never use the login screen.
well, skins are processed this way:
Login.xml > Startup.xml > Home.xml
at the login screen your libraries haven't been setup as you haven't selected a profile yet.
i would find it very confusing if login/startup would have the opposite meaning in addons.
right, login seems to be the safest way to do this.
will edit my previous post accordingly.
thx Martijn :-)
Thanks for the info!
I only have one profile myself so didn't run into any problems.
Fixed my original post.
edit: Okay, I found the options in settings and it worked, updating and copying over correctly to the directory. However, I have no fanart for the TV and Movie items, even though I have that checked
Just black background.
(2012-04-07, 23:32)colbert Wrote: [ -> ]edit: Okay, I found the options in settings and it worked, updating and copying over correctly to the directory. However, I have no fanart for the TV and Movie items, even though I have that checked Just black background.
if the script correctly copied the artwork to the new directories then it must be a skin issue.
Hi ronie.
Just got a question regarding this add-on.
I've added all my music in my library and let XBMC automatically download all fanarts, thumbs,etc... will this add-on be able to organize the downloaded artwork and into the different artists folders? (instead of just one folder)
My music is organized like so
Music
--- Genre
-----------Artist (i'd like to store artist thumb and fanart at this level)
-------------- Album
Is this something that Artwork Organizer can do? The reason I'm asking is because it gets cumbersome having to download all the artwork every time I do a fresh install of XBMC
(2012-04-15, 03:49)iLurk Wrote: [ -> ]Is this something that Artwork Organizer can do? The reason I'm asking is because it gets cumbersome having to download all the artwork every time I do a fresh install of XBMC
nope, but the 'export music library' option in xbmc does exactly what you're after ;-)
(2012-04-15, 11:53)Martijn Wrote: [ -> ] (2012-04-15, 11:29)ronie Wrote: [ -> ] (2012-04-15, 03:49)iLurk Wrote: [ -> ]Is this something that Artwork Organizer can do? The reason I'm asking is because it gets cumbersome having to download all the artwork every time I do a fresh install of XBMC
Or cdart manager
Thanks fellas. i've always assumed that the "export music library" just created a db file in the user folder (dont know where I got that idea from) either way... all's well now
Thanks again
so.. the script seems to have worked fine.. as it transferred over all of the .tbn to the correct folder.. but its not showing any of the tvshows/movies fanart on the main screen.. its just a black screen.. i'm using aeon mq3.. its an option for the actual skin.. should I ask there or in here?
http://pastebin.com/EB0GxZFL
