YOU ARE THE MAN FernetMenta!!!! I just finished testing your pvr build with the cHD hack and so far things are working great. I am going to do some more Live TV testing right now and report more detailed results after a period of watching. Here are the debug logs for Live H264 HDTV with xbmc addon xvdr.
17:35:36 T:2967468912 DEBUG: CrystalHD: Format Change Detected. Flags: 0x00030000
17:35:36 T:2967468912 DEBUG: ----------------------------------
17:35:36 T:2967468912 DEBUG: TimeStamp: 0
17:35:36 T:2967468912 DEBUG: Picture Number: 0
17:35:36 T:2967468912 DEBUG: Width: 1280
17:35:36 T:2967468912 DEBUG: Height: 720
17:35:36 T:2967468912 DEBUG: Chroma: 0x001
17:35:36 T:2967468912 DEBUG: Pulldown: 9
17:35:36 T:2967468912 DEBUG: Flags: 0x00000800
17:35:36 T:2967468912 DEBUG: Frame Rate/Res: 0
17:35:36 T:2967468912 DEBUG: Aspect Ratio: 1
17:35:36 T:2967468912 DEBUG: Color Primaries: 16843008
17:35:36 T:2967468912 DEBUG: MetaData: 0
17:35:36 T:2967468912 DEBUG: Session Number: 0
17:35:36 T:2967468912 DEBUG: Custom Aspect: 0
17:35:36 T:2967468912 DEBUG: Frames to Drop: 0
17:35:36 T:2967468912 DEBUG: H264 Valid Fields: 0x00000000
17:35:36 T:2967468912 DEBUG: CrystalHD: dec_par x = 1, dec_par y = 1
17:35:36 T:2967468912 DEBUG: CrystalHD: resolution = 0 interlace = 0
17:35:36 T:2946489200 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
17:35:36 T:8792736 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 0
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 1
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 2
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 3
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 4
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 5
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 6
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 7
17:35:36 T:2967468912 DEBUG: Previous line repeats 1 times.
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 8
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 9
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 10
17:35:36 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 11
17:35:36 T:2956979056 DEBUG: AddOnLog: VDR XVDR Client: SendPing
17:35:36 T:3053443952 DEBUG: CDVDPlayer::HandleMessages - player started 2
17:35:37 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 12
17:35:37 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84475566838.267975, should be:84475432437.632416, error:-134400.635559
17:35:37 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 13
17:35:38 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 14
17:35:38 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84476472180.254410, should be:84476455412.958954, error:-16767.295459
17:35:38 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84476610462.074951, should be:84476726886.912735, error:116424.837784
17:35:38 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 15
17:35:38 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 16
17:35:39 T:2967468912 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 17
17:35:39 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84477783373.561737, should be:84477838960.381912, error:55586.820177
17:35:40 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84478875564.544907, should be:84478822274.254776, error:-53290.290125
17:35:41 T:2759822192 DEBUG: CDVDPlayerAudio:: Discontinuity - was:84479901986.263779, should be:84479875295.793900, error:-26690.469880
17:35:42 T:2956979056 DEBUG: AddOnLog: VDR XVDR Client: SendPing
17:35:44 T:8792736 DEBUG: LIRC: Update - NEW at 370543:000000037ff07bd9 00 Guide mceusb (Guide)
17:35:44 T:8792736 DEBUG: OnKey: 229 (e5) pressed, action is CodecInfo
17:35:48 T:2956979056 DEBUG: AddOnLog: VDR XVDR Client: SendPing
17:35:50 T:8792736 DEBUG: LIRC: Update - NEW at 376443:000000037ff07bd9 00 Guide mceusb (Guide)
17:35:50 T:8792736 DEBUG: OnKey: 229 (e5) pressed, action is CodecInfo
17:35:54 T:2956979056 DEBUG: AddOnLog: VDR XVDR Client: SendPing
17:35:57 T:8792736 DEBUG: LIRC: Update - NEW at 383910:000000037ff07be6 00 Stop mceusb (Stop)
17:35:57 T:8792736 DEBUG: OnKey: 224 (e0) pressed, action is Stop
