2011-09-05, 07:59
Well i just tryed adding a RSS feed from my local journal to XBMC, now i'm getting this error when trying to edit feeds:
Error: Rssfeeds.xml
Rssfeeds.xml was either not found in the system, or does not contain parsable XML. Try deleting the file from data folder and restarting XBMC
So i tryed deleting this file:
C:\Program Files\XBMC\userdata\Rssfeeds.xml
but i keep getting the same error !!!
here was my file:
i dont understand what went wrong.... its a valid RSS feed...
Error: Rssfeeds.xml
here was my file:
Quote:<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<rssfeeds>
<!-- RSS feeds. To have multiple feeds, just add a feed to the set. You can also have multiple sets. !-->
<!-- To use different sets in your skin, each must be called from skin with a unique id. !-->
<set id="1">
<feed updateinterval="30">http://www.cyberpresse.ca/rss/179.xml</feed>
</set>
</rssfeeds>
