2011-09-05, 18:30
i got the build from 2nd of september installed which has already Airplay in XBMC integrated.
Also i installed the direct boot into XBMC (apt-get install org.tomcool.xbmc-booter). If i now start an Airplay stream from my iPhone4 xbmc reboots.
I installed "top" to watch what processes are running. I see even if i boot directly into xbmc the process AppleTV is runnig by nearly 100% cpu and there is another process called airtunesd. I thought if i kill airtunesd the airplay network port is free for the XBMC Airplay implementation but the process airtunesd is always restarting if i kill him with killall airtunesd. And wtf why is AppleTV running if i'm directly booting into XBMC?
Here are my specs:
XBMC Build: xbmc-20110902-139071b-master-atv2
iOS: 4.2.2
pastebin XBMC Log: http://pastebin.com/3XNaAp3E
pastebin "top": http://pastebin.com/tWFZsrHN
Thanks in advance
Best regards
regnets
[EDIT]
After a hard reboot i found a new airplay target on my iphone XBMC@Living-Room-AppleTV...
Now XBMC doesnt reboot, but it just shows Working... and my iphone displays Cannot play video on "XBMC@Living-Room-Apple-TV"
Here is a new XBMC log: http://pastebin.com/Nb0pyz76
There are some error messages at the bottom.
Is there a way to disable the native Airplay (kill the watchdog )
[/EDIT]
[NEXTEDIT]
After killing AppleTV Process i tried it another time.
I just saw the video for a second and then it falls back to the main menu.
Tried it another time.
Same thing as in the first edit.
Here is the XBMC log with the 1 second video: http://pastebin.com/mBNyrxsN
Thank you for your time
[/NEXTEDIT]
[THEEDITAFTERNEXT]
Now i got it working dont know what was wrong
Heres the new log: http://pastebin.com/fyxcKiCm
I hope you can use it.
Sorry for spamming
[/THEEDITAFTERNEXT]
[HOPEFULLYTHELASTEDIT]
Now it seems to be perfectly working
I just wish to deactivate the natively Airplay
[/HOPEFULLYTHELASTEDIT]
Here are my specs:
iOS: 4.2.2
Thanks in advance
Best regards
regnets
[EDIT]
[/EDIT]
[NEXTEDIT]
[/NEXTEDIT]
[THEEDITAFTERNEXT]
Sorry for spamming
[/THEEDITAFTERNEXT]
