Full Version: Chroumium Browser in XBMC Font Problem
Hi all
im a bit stuck hoping for some help
I have XBMC installed on Ubuntu 11.04 Server and most things are running fine
Ive decided to try and get a browser installed so have installed chromium and that is opening up through the advanced launcher plugin
I did have a problem with only half of the display being used
ive now installed fluxbox wm and played with that so that when switching to chromium the screen is now fully used - I think there are two windows in use under fluxbox
Im happy so far
The problem I have now is that the font size in the browser is really small
Ive played with the xorg.conf and added Option "DPI" "200 x 200" and so on
That does do something to the toolbar I have in the bottom of the screen but thats all - the browser text stays the same
heres my xorg.conf as it is now
#Configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 270.41.06 ([email protected]) Mon Apr 18 15:14:00 PDT 2011
Section "Device"
Identifier "nvidia"
Driver "nvidia"
Option "NoLogo" "true"
Option "DynamicTwinView" "false"
Option "NoFlip" "false"
Option "FlatPanelProperties" "Scaling = Native"
Option "ModeValidation" "NoVesaModes, NoXServerModes"
Option "UseDisplayDevice" "DFP-1"
Option "ModeDebug" "true"
Option "HWCursor" "false"
EndSection
Section "Screen"
Identifier "screen"
Device "nvidia"
SubSection "Display"
Modes "1920x1080" "1920x1080_60" "1920x1080_60_0" "1920x1080_50" "1920x1080_24" "1920x1080_60i" "1920x1080_50i" "1280x1024" "1280x1024_60" "1280x720" "1280x720_60" "1280x720_60_0" "1280x720_50" "1024x768" "1024x768_60" "800x600" "800x600_60" "720x576" "720x576_50" "720x576_50i" "720x480" "720x480_60" "720x480_60i" "640x480" "640x480_60"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "false"
EndSection
Does anybody have any idea what I can try to get the font size bigger in the browser
thanks for any guidance
There is a "Minimal Font Size" option into Chromium. You Need to go to Preferences / Advanced Options / Customize Fonts. Here you can increase the minimum font size to 24. Then you can also play with the Chromium zoom option CTRL+/CTRL- to fit the webpage to the wide of your screen.
