Full Version: MySQL continuous scanning + other weirdness
Hey guys. I've been (unsuccessfully) trying to get MySQL working with XBMC for some time now and it's just not working. Here is a quick breakdown.
  • Library on a media server
  • Movies and TV Shows folders are mapped using SMB
  • I have the advancedsettings.xml in the correct folder
  • Content info has already been scrapped is in each show/movie folder
Basically it starts to scanning and won't stop. I didn't think it would scan if it already found info in the folders. It's also only showing the first episode of TV Shows in Library mode. Everything is fine if its local.
Also, I used to have M: mapped to movies and T: mapped to TV Shows but I understand MySQL doesn't like the \ or something so I switched everything to SMB paths. I've uninstalled, deleted the appdata folder and re-installed using only the SMB paths. Everything fails and I check the log and it's still making reference to M: and T: which are no longer mapped on my system. I have no idea where its coming from. Anyway, here is the last log.
Any ideas? Thanks.
XBMC Log
