2011-09-06, 20:38
for some odd reason i thought i would run:
sudo apt-get update
sudo apt-get upgrade
and it went smooth until it was done, (i was asked a few times if i wanted to keep or replace existing config files, i chose replace after comparing and seeing it was just a few diff's)
on reboot i get the very rough looking ubuntu loading which quickly reports an error about nForce2 smbus and ultimately fails on a popup box so small i cant read the writing.
anyone have a quick fix for me to get back to where i was?
Thanks,
-aPeg
sudo apt-get update
Thanks,
-aPeg
