Full Version: t0mm0 Repository
just found t0mm0's Repository and realised there is an error in the xml file.
https://github.com/t0mm0/t0mm0-xbmc-plug...aster/repo
the respitory has ..../raw/master/repo
replace raw with tree, save rezip and continue to import the zip file and you'll get another set of addins to install on your atv2.
so far in Australia crackle and 8tracks are both working.
earthboyrod Wrote:just found t0mm0's Repository and realised there is an error in the xml file.
in case anyone else sees this - i believe this is not right. it will not work correctly if you make these changes. the original zip works fine.
if someone can provide a log showing otherwise i'd be very interested Wink
thanks,
t0mm0
I have no problem getting the repo without any modifications.
very odd, why am i so special. oh well, if i knew how to delete this thread i would now
