Full Version: [Request] Update library with basic buttons
Some skins make it possible to update the library using only the up/down and enter buttons.
For example in Aeon Nox you can do it from the home page, when you go to Movies and press 'down' one of the options is to update the library.
Would it be possible to introduce this feature for the next version of Confluence? It is pretty handy for people who only have basic remote controls.
That's a pretty good idea.
You could always add this a favorite as a quick fix.
Surely you have a remote button that has no function on the home screen just map update library to that button then it will be available in all skins
voochi Wrote:Some skins make it possible to update the library using only the up/down and enter buttons.
Update library is also available from the 'C' (context) menu.
