Full Version: new AFPClient for iOS/OSX <--SOLUTION FOR LION USERS
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
I just installed the latest nightly. I have been using AFP a few days now with no problems and better performance than NFS.
However with the new build installed i can no longer get it to update my library. Its scans movies and tv show but dosnt find anything.
This is what it says in the log (the same lines for all my content):
[HTML]01:02:03 T:122101760 DEBUG: AFP: Using anonymous authentication.
01:02:03 T:122101760 DEBUG: VideoInfoScanner: No (new) information was found in dir afp://10.0.1.8:548/tvshows/Entourage/[/HTML]
However i know that there are new shows to update. Any ideas?
hmm... update.. some might need the beginning of the scan log:
[HTML]01:01:54 T:122101760 NOTICE: VideoInfoScanner: Starting scan ..
01:01:54 T:122101760 DEBUG: AFP: Using anonymous authentication.
01:01:54 T:115445760 DEBUG: Previous line repeats 1 times.
01:01:54 T:115445760 DEBUG: Thread Background Loader 115445760 terminating
01:01:56 T:122101760 DEBUG: VideoInfoScanner: Rescanning dir 'afp://10.0.1.8:548/movies/' due to change (fast1315852207 != FD44DEAD83F3DAA74B50CD07FEC5551F)
01:01:56 T:122101760 DEBUG: GetMovieId (afp://10.0.1.8:548/movies/Depeche Mode - One Night in Paris - The Exciter Tour 2001.mkv), query = select idMovie from movie where idFile=569
01:01:56 T:104710144 INFO: Python, unloading python shared library because no scripts are running anymore
01:01:56 T:122101760 DEBUG: GetMovieId (afp://10.0.1.8:548/movies/louis.c.k.hilarious.2010.hdtv.xvid-fqm.avi), query = select idMovie from movie where idFile=1
01:01:56 T:122101760 DEBUG: GetMovieId (afp://10.0.1.8:548/movies/RADIOHEAD LIVE IN PRAHA.mov), query = select idMovie from movie where idFile=2
01:01:56 T:122101760 DEBUG: GetMovieId (afp://10.0.1.8:548/movies/Sammy's Adventures.m4v), query = select idMovie from movie where idFile=3
01:01:56 T:122101760 DEBUG: GetMovieId (afp://10.0.1.8:548/movies/U2_ELEVATION_2001_DISC1.mkv), query = select idMovie from movie where idFile=4
01:01:56 T:122101760 DEBUG: Mysql execute: update path set strHash='fast1315852608' where idPath=1
01:01:56 T:122101760 DEBUG: VideoInfoScanner: Finished adding information from dir afp://10.0.1.8:548/movies/
01:01:56 T:122101760 DEBUG: AFP: Using anonymous authentication.
01:01:56 T:122101760 DEBUG: VideoInfoScanner: Skipping dir 'afp://[/HTML]
not related to afp ... others are reporting this too...
ctawn Wrote:How can we change all our existing SMB sources to AFP sources properly? (I shudder to think what adding hundreds of videos, including thumbnails and fan art stored on the server with the videos, back to my video/movie library would be like, if there weren't some kind of global search and replace option.)
This might help you out: http://wiki.xbmc.org/index.php?title=HOW...base-files
And a related question: I'm using a shared library with MySQL running on the same server as my media library and master XMBC installation. So, on this server the shares are all local (and AFP doesn't seem to work since it is on the same machine - which makes sense)..
Is there a way to substitute the local links to AFP links on the ATV2?
despartio Wrote:And a related question: I'm using a shared library with MySQL running on the same server as my media library and master XBMC installation. So, on this server the shares are all local (and AFP doesn't seem to work since it is on the same machine - which makes sense)..
Network links will still work even on the local machine. If AFP isn't working for this then post your XBMC.log (with debugging on) and maybe we can see what's happening.
Ned Scott Wrote:Network links will still work even on the local machine. If AFP isn't working for this then post your XBMC.log (with debugging on) and maybe we can see what's happening.
Heres the log from my Mac Mini that encounters the problem. Tried with both the local name of the Machine as well as IP without success... Might be something I have configured wrong?
try adding your afp source manually as afp://user:password@ip/share. For ip don't use 127.0.0.1 but the lan ip of your macmini.
Memphiz Wrote:try adding your afp source manually as afp://user:password@ip/share. For ip don't use 127.0.0.1 but the lan ip of your macmini.
Didn't work either, but found a link regarding pathsubstitution and that seems to do the trick!
Just wanted to say that it works very well for me on my iPad. Performance is much better than the FTP solution.
I have two Windows XBMC install. They don't have AFP support, correct?
ashgotti Wrote:Just wanted to say that it works very well for me on my iPad. Performance is much better than the FTP solution.
Not yet. We have to bait one of the Windows devs into including it.
This thread has come into being as if by magic at the exact moment I needed it. Thank you, wizards.
I assume this is JB iPad?
Thanks,
I have the latest jailbreak forvthe atv 2 and have enabled afp on my new iMac when i add a source, with zeoconfig I see the public folder but not my movie folder, this is on my external USB drive I have gone into sharing and set this to share but it won't show up
Have I missed a step!!
Atv 2
Software 4.22
And latest build 2011916
Paul
Been on google this afternoon, I think the problem is that my usb drive is formatted as ntfs, I take that means that the atv 2 cannot see that format if i use the afp function on the iMac, its lists the public folder,and my external drive but because the usb drive is ntfs it can't, is this correct?? If thats the case is there a workaround, I have over 500gig of movies, on the drive and I really don't want to have to reformat.
Paul
AFP is AFP ... as long as your AFP Server (your imac) let you enable shareing for the drive it shouldn't matter which filesystem is on it. Did you try to add the source manually with username and password? (zeroconf only can do anonymous auth - if you didn't have configured your macosx for allowing this - it will fail ...)
So try to add your source manually as
afp://username:password@ipofyourimace/sharedfolder
