2011-09-09, 14:20
Hi iv just purchased a Wesena itx6 case with the internal ir. Does anyone know if this will work out the box with xbmc live or will i need to do a marothon install job. This is the link to the product: http://www.wesena.co.uk/product.php/18/5/rc260
Just woundering if anyone has successfully used this under a live install will it use the lirc driver.
