Hello guys!
Is it possible to combine movies into boxsets, only with SQL DB? Witout need for .nfo files ... ?
If yes, could you tell me HOW?
Thanks for your time guys!
I think you just create the .nfo files only once, update your library, and then you can delete them. I don't believe XBMC constantly scans .nfo files, but rather just reads them once and puts them into its DB.
Ned Scott Wrote:I think you just create the .nfo files only once, update your library, and then you can delete them. I don't believe XBMC constantly scans .nfo files, but rather just reads them once and puts them into its DB.
You are pretty right! Using the .NFOs, XBMC writes the box sets into MySQL.
I can see the "sets" and "setlinkmovie" tables, containing the information needed for stacking.
The problem now is, that I cannot edit "setlinkmovie" table ... which is most likely generated from
some other tables.
But
I cant find out, which tables that are ...
Anybody ever investigated that ??
