Full Version: Home Cinema Experience with MPC
Hello guys,
I have a quick question to ask you guys. Is it possible to make MPC start after Cinema experience is done?? If so, can you guys link me the command to type in the playercore. Thanks everyone.
Can you clarify the question? If you're trying to use MPC-HC as an external player have a quick search through the Windows forum and there should be lots of examples. A quick search found http://forum.xbmc.org/showthread.php?tid=109799 and looks like a good starting point.
JR
