So I just moved addresses and I updated/re-jailbroke my Apple TV with sn0wbreeze and I can't get my setup running again. SMB works fine on my roommates Macbook it just can't access my windows PC.
I've tried every post I could find but I can't seem to figure it out.
Info:
XBMC Build: XBMC Pre-11.0 GIT:20110623-62171b3 (Compiled: June 23 2011)
Acquired via nitoTV gui
Apple TV build 4.2.2 (2203)
Log file:
http://pastebin.com/JajqDJ6z
Problem: Adding source via SMB results in Error 2. Adding network source manually results in time out.
You might want to obscure your passwords...
And I'm not sure if this is still relevant, but on the linux/xbox build Windows Live Essentials broke SMB for a very long time, any chance you can check whether it is installed on the Windows PC?
Shadow_Mx Wrote:You might want to obscure your passwords...
Yes I've already removed that completely
Ned Scott Wrote:try upgrading to the latest nightly build. It as a ton of fixes since the build you have.
http://wiki.xbmc.org/index.php?title=Ins...htly_build
Still no go. The Mac share works perfectly, trying to manually add a source results in an instant connection timed out with no delay.
ashika22 Wrote:Still no go. The Mac share works perfectly, trying to manually add a source results in an instant connection timed out with no delay.
Please post full debug log with latest build .. Have you tried using running xbmc on the macbook and accessing windows share ? Is this windows 7 ?
CrashX Wrote:Please post full debug log with latest build .. Have you tried using running xbmc on the macbook and accessing windows share ? Is this windows 7 ?
Its not my Mac (its my friends who came by and set up sharing) so I can't readily do that, it is windows 7 and here is the log:
http://pastebin.com/mSFgUbBe
The first couple attempts I was on the VPN and it didnt work so I disconnected, the last couple of attempts I was not on the VPN and it couldn't find anything.
This is with the 9-11 nightly
What on earth are you going on about with a VPN? Are the ATV and the laptop on the same network? You really need to describe what your setup is like and what you are trying to do.
You are using username and password in your share at the moment.
Set up simple file sharing on your windows box. Get it working with the Guest account. That way no usernames or passwords are needed.
Once you can browse your windows box properly and add sources, then try and lock it down - if needed.
http://www.home-network-help.com/file-sh...ows-7.html
Yes same network. Currently I disabled everything, I set up a guest account with access to the folder, when I manually add the source I hit a connection timed out instantly, with no delay.
If SMB is working properly with guest access you should be able to create a source by browsing to the share, and access it without any IP addreses, usernames or password.
It should work like this :
http://www.youtube.com/watch?v=fXS933EECQU
If it doesn't there is still something wrong with your PC setup. There is very little you can change or need to change on the ATV2.
